[SOLVED] System goes to Sleep Mode automatically and then Blue Screen..
csinner
I would like an opinion for a system that has intel board (Intel Stone Desktop). I have installed windows 7 with 2 GB RAM. System randomly after 1 or 3 hours ( no standar time) goes to auto sleep and then blue screen. I have changed the memory but it stills do the same thing.. I will post dumb file and info.. If anyone knows something i would like to hear his opinion..
The attached DMP file is of the VIDEO_TDR_FAILURE (116) bug check.
This indicates that an attempt to reset the display driver and recover from a timeout failed.
So, let me now explain what VIDEO_TDR_ERROR means. First off, TDR is an acronym for 'Timeout Detection and Recovery'. Timeout Detection and Recovery was introduced in Vista and carried over to Windows 7. Rather than putting exactly what Timeout Detection and Recovery does exactly, I'll just directly quote the MSDN article!
Timeout detection:
The GPU scheduler, which is part of the DirectX graphics kernel subsystem (Dxgkrnl.sys), detects that the GPU is taking more than the permitted amount of time to execute a particular task. The GPU scheduler then tries to preempt this particular task. The preempt operation has a "wait" timeout, which is the actual TDR timeout. This step is thus the timeout detection phase of the process. The default timeout period in Windows Vista and later operating systems is 2 seconds. If the GPU cannot complete or preempt the current task within the TDR timeout period, the operating system diagnoses that the GPU is frozen.
To prevent timeout detection from occurring, hardware vendors should ensure that graphics operations (that is, DMA buffer completion) take no more than 2 seconds in end-user scenarios such as productivity and game play.
Preparation for recovery:
The operating system's GPU scheduler calls the display miniport driver's DxgkDdiResetFromTimeout function to inform the driver that the operating system detected a timeout. The driver must then reinitialize itself and reset the GPU. In addition, the driver must stop accessing memory and should not access hardware. The operating system and the driver collect hardware and other state information that could be useful for post-mortem diagnosis.
Desktop recovery:
The operating system resets the appropriate state of the graphics stack. The video memory manager, which is also part of Dxgkrnl.sys, purges all allocations from video memory. The display miniport driver resets the GPU hardware state. The graphics stack takes the final actions and restores the desktop to the responsive state. As previously mentioned, some legacy DirectX applications might render just black at the end of this recovery, which requires the end user to restart these applications. Well-written DirectX 9Ex and DirectX 10 and later applications that handle Device Remove technology continue to work correctly. An application must release and then recreate its Direct3D device and all of the device's objects. For more information about how DirectX applications recover, see the Windows SDK.
With this being said, if Timeout Detection and Recovery fails to recover the display driver, it will then shoot the 0x116 bugcheck. There are many different things that can cause a 0x116, which I will explain below:
MODULE_NAME: igdkmd32
IMAGE_NAME: igdkmd32.sys
FAILURE_BUCKET_ID: 0x116_IMAGE_igdkmd32.sys
^^ Intel Graphics Driver.
0: kd> lmvm igdkmd32
start    end        module name
8ea1e000 8ef1b000   igdkmd32 T (no symbols)
    Loaded symbol image file: igdkmd32.sys
    Image path: \SystemRoot\system32\DRIVERS\igdkmd32.sys
    Image name: igdkmd32.sys
    Timestamp:        Wed May 06 14:13:40 [COLOR=#ff0000][I][B]2009 [/B][/I][/COLOR](4A01D354)
Dated from 2009.
Ensure you have the latest video card drivers. If you are already on the latest video card drivers, uninstall and install a version or a few versions behind the latest to ensure it's not a latest driver only issue. If you have already experimented with the latest video card driver and many previous versions, please give the beta driver for your card a try.
Regards,
Patrick
Thank you very much.. i appreciate that you wrote so analytic answer to my post.. I will check the drivers and i will reply with the results..
I downloaded vga drivers from Stone official site (year 2011), also i changed the Ram and now the system is working 100%.. Thank you !
