Test RAM with memtest.org MemTest86+ (tutorial made with version 7.20)
  1. Follow the instructions below for running MemTest86+ from either a USB stick or CD/DVD (i.e., you don't need both).
  2. Leave the USB stick, or CD/DVD, inserted.
  3. The USB stick should be able to boot on any computer in old BIOS/CSM Mode or in modern UEFI 32/64 bits.
    Memtest86+ DOES NOT (actually) supports Secure Boot.
    If enabled, Secure Boot must be temporarily disabled before trying to boot on this USB Key.
    To access the bios/uefi settings, reboot your computer.
    During the initial stages of the boot process, press the applicable key as prompted.
    As an example, DEL is usually the key for the bios/uefi settings on ASROCK motherboards.
    If you don't know the key for your system, check your motherboard manual or this tutorial:
    Get access to BIOS settings & Boot Menu: F-keys/Hotkeys by System Manufacturer (OEM) (click).​
    If Secure Boot is enabled, disable it and save the settings.
    (Be prepared to press the applicable key to access the boot menu. You can find it like the one for bios/uefi settings)
    Exit from the BIOS/UEFI settings.
  4. Press the applicable key to access the boot menu.
    As an example, F11 is usually the key to access the boot menu on ASROCK motherboards.​
    Select the USB stick, or the CD/DVD disc, with MemTest86+ on it.
  5. If the program won't start after a few of seconds, and you'll be redirected to the boot menu, you'll have to enable the CSM (Compatibility Support Module) in your BIOS settings.
    This is also known as Launch CSM or boot: legacy (instead of boot: uefi).
    If you can't find CSM, it could be necessary to disable the Fast boot feature (in your BIOS settings).
  6. Wait a few of seconds and MemTest86+ will be available on your screen.
    You can use the letters between parenthesis to access its menus.
    Note:
    In version 5.01, Simultaneous Multi-Threading (SMT) and Symmetric multiprocessing (SMP) were introduced.
    These are features designed to speed up test times.
    If you need, or want, to disable this feature, press the F2 key within a few seconds of booting into MemTest86+.​
  7. Available menus:
    • Esc key: to exit the program
    • F1 key: to enter in configuration
    • Space: scroll lock or scroll unlock (???)
  8. Wait until it reaches at least 8 passes or until an error appears.
    This test could take few hours.
    Added by Philc43: as an example, on some systems with 32GB RAM could take 1-2 days.
    In this case it can be an advantage to breakdown the testing into steps of one or two modules at a time and run the tests overnight.​
  9. Added by Philc43: when errors are found with a single stick, it is also worth testing that stick in other slots to check that the errors are not due to a MB slot problem.
    Follow the instructions here (click) (after the warning) to know how to manually switch memory modules.
Screenshots
Notes:
The steps to create CD/USB bootable media were originally posted by admin Tekno Venus.
I expanded them and then added also other users' experiences.
Thanks for this updated version. Could I also suggest you add a comment about the length of time it takes? For example a 32GB system could take 1-2 days on some systems. In this case it can be an advantage to breakdown the testing into steps of one or two modules at a time and run the tests overnight.
Also note that when errors are found with a single stick it is also worth testing that stick in other slots to check that the errors are not due to a MB slot problem.
Nice guide.
The only thing I would add is every live CD/DVD which is created by Linux will have included the Memtest86.
I love the fact you have explained the booting sequences that is something most people might miss when they trying to boot.
Again great work I love the guide. :thumbs_up:
Write your reply...
