Prime95 Hardware Stress Testing Steps:
- Download Prime95 (The latest version is 30.19 build 20, June 2, 2024, at the time of editing)
- Navigate to where you saved the Prime95 files and unzip the files.
- Open Prime95 from the list, and then click Run in the dialog box if it opens.
- Click Just Stress TestingRead More:
- Run Small FFTs, In-place large FFTs, and Blend for a few hours each.
Report back if CPU temperatures reach dangerous levels, if the system crashes, or if hardware errors are discovered by the diagnostics.Read More:- Real Temp 3.70 (16th January 2012) is a good CPU temperature monitor.
- Speccy free will monitor all hardware temperatures.
- HWiNFO - Hardware Information and Analysis Tools can be inaccurate for CPU temperatures, but is a good program for GPU temperature monitoring.
