A thread of mine on the forum was closed before being answered, because it was by some manner accidentally linked to a way to bypass Windows 7 activation within the first 30 days, even if my trouble was not related to Windows activation. It makes no doubt that the moderator took the right decision at closing my thread and that the mistake was mine : I should have focused only on the problem which I wanted to get fixed and not have digressed on Windows activation considerations, which had likely nothing to do with the issue itself.
I may post once again about the same issue within a new thread, not making any reference to Windows activation does and don't. However, I wonder if this is compliant with the rules of the forum ? In other words, may I push back to the forum an issue which got discarded by a moderator just by removing the part that caused my thread to be closed prematurely ?
The post I am referring to his available here : WIN 7 - slmgr - "ActiveX component can't create object" error (code 800A01AD)
The new phrasing which I may use to describe the same issue might be like that : On my machine, the slmgr tool ceased to respond correctly. Typing slmgr /dlv or even slmgr alone produces such an output : activex component can't create object 'scripting.dictionary'. The re-registration of scrrun.dll did not help.
Is that way of doing complies with the rules of the forum ?
Thank you for your advices.
