Re: W10 - KB4074588 error 8007005, SFC failing on deltastore.cpp STATUS_INVALID_PARAM
I followed your instructions, but the size of the produced file is 5 gigabytes. Is that typical and should I really upload it? (zipped size is 474 MB)
However, I'm not sure if I can capture the exact moment when the things go wrong. The whole update process goes like this:
1) I go to Control Panel, Windows Update, and click the button to find new updates
2) KB4074588 is found and it starts downloading
3) After it's finished, it asks me to restart the machine
4) I click the restart button, then I get the cyan screen with spinning dots saying "Getting Windows ready. Don't turn off your computer." It stays like this for approximately one minute, then the message changes to "Restarting" and the computer restarts. Nothing else is displayed (like "XX% completed").
5) After Windows boots up, the same message ("Getting Windows ready...") is displayed for a few seconds. Then the login screen appears and I log in.
6) After half a minute or so, the message is displayed that the update failed to install (in the bottom right corner). When I click it, it opens the Windows Update control panel which says that the update encountered error 0x80070057.
