1935 error
jhgreene
Well-known member
posting here following a PM with niemiro
this problem was identified when trying to install drivers and s/w for brother QL-570 printer from the manufacturer CD
failed install picture at
https://www.dropbox.com/s/ztb0uxw70g8vw2z/ql_install_error_1.png?dl=0
and
https://www.dropbox.com/s/5ocbtmmq4ec5eot/ql_install_error_2.png?dl=0
then tried to fix
stop anti virus
stop firewall
removed and reinstalled .NET versions 1.1, 3.5, 4, 4.5
updated and verified
removed and reinstalled visual c++ 2005, 2008, 2010, 2012
then tried the QL-570 install again
same error
(screaming) :banghead:
advice from niemiro
run SURT
post logs here
he said error isnt too drastic ......
SURT is running now will zip and add to thread when done
thanks in advance
Windows update was trying apply a C++ KB and failed giving a 643 error
MSFixit50123 failed to repair it
prof google says its a .net error
:mad:
ms .net framework verification tool says ok for 3.5, 4, 4.5, 4.51 and 4.5.2
SFCfix found some corrupt files it couldnt fix
They were ok the other day !!
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9\vcomp90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff\vcomp90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.21022.8_none_6dee77c650852292\MFC90CHT.DLL
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.21022.8_none_b59bae9d65014b98\MFC90CHT.DLL
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.21022.8_none_7644f34b9721eccf\ATL90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.21022.8_none_bdf22a22ab9e15d5\ATL90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.21022.8_none_706fccb39ad7e580\mfc90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.21022.8_none_b81d038aaf540e86\mfc90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58\MFC90CHT.DLL
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e\MFC90CHT.DLL
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\ATL90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\ATL90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c\mfc90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.21022.8_none_a5325551f9d85633\vcomp90.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.21022.8_none_ecdf8c290e547f39\vcomp90.dll
CORRUPT: C:\Windows\winsxs\amd64_microsoft.vc80.openmp_1fc8b3b9a1e18e3b_8.0.50727.6195_none_f364d326b5304e6e\vcomp.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft.vc80.openmp_1fc8b3b9a1e18e3b_8.0.50727.6195_none_3b1209fdc9ac7774\vcomp.dll
CBS & SFC total detected corruption count: 40
SURT total detected corruption count: 41
now both box and drop fail with side by side errors
along with visual c++ update
Product: Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 -- Error 1935.An error occurred during the installation of assembly 'policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.6161",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"'. Please refer to Help and Support for more information. HRESULT: 0x80070003. assembly interface: IAssemblyCache, function: CreateAssemblyCacheItem, component: {7EBE1AE9-B7D3-3CE1-A4D3-45F77EE0C487}
Hello,
Sorry for the delay in responding to you.
This might take a couple of rounds to get everything repaired.
lets start of with repairing some of these system files.
SFC /SCANNOW
  1. Click on the
  4. Please wait for this to Finish before continuing with the rest of the steps.
Please run SURT again, once this has finished please upload the following:
Export CBS folder
  1. Click the Start button
    then click Computer.
  2. Double-click on the C: drive, under the Hard Disk Drives category, and then scroll down to, and double click on the Windows folder.
  3. Find and double click on the Logs folder.
  4. Right-click on the CBS folder, and select Copy.
  5. Go back to your Desktop, right-click on it, and select Paste. You should now see a copy of the CBS folder appear on your Desktop called CBS.
  6. Right-click on this new folder, and navigate through Send to, and select Compressed (zipped) folder.
  7. A new file, also called CBS (CBS.zip), but this time with a different icon, will be created.
  8. Attach this to your next post please.
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or One Drive
hi
SFCFix log below
CBS log at link
https://my.pcloud.com/publink/show?code=XZztTkZcJ7AL5uEddQzzgnLw15xqBdjiWD7
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-02-18 08:56:17.978
Using .zip script file at C:\Users\jhg\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff\vcomp90.dll to C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff\vcomp90.dll.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c\mfc90.dll to C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c\mfc90.dll.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e\MFC90CHT.DLL to C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e\MFC90CHT.DLL.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\ATL90.dll to C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b\ATL90.dll.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9\vcomp90.dll to C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9\vcomp90.dll.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90.dll to C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146\mfc90.dll.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58\MFC90CHT.DLL to C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58\MFC90CHT.DLL.
Successfully copied file C:\Users\jhg\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\ATL90.dll to C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895\ATL90.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_80ba6c811e9b4aff
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_4bf7e3e2bf9ada4c
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_49768ef57548175e
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_51cd0a7abbe4e19b
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.6161_none_390d35aa0a1f21f9
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_044aad0bab1eb146
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.6161_none_01c9581e60cbee58
Successfully restored ownership for C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895
Successfully restored permissions on C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.6161_none_0a1fd3a3a768b895
SFCFix version 2.4.3.0 by niemiro has completed.
Currently storing 25 datablocks.
Finish time: 2015-02-18 08:56:20.116
Script hash: Wq+hsvOasjpEMlmP6X0Ul6JsXkP2XoFo/hsdJ20JMSA=
hi
the list of failing apps is growing; box, dropbox etc
awaiting your instructions
jg
Dont worry I haven't forgot about you :) It is just getting some of these files can often be a lot more work than normal, I need to set up a VM to install an update to gather these files.
er ok
niemiro said the error wasnt too much of a big deal....
i am finding more and more apps that a crapping out, evernote was the latest one
do you need to remote in ?
what about the time diff
i can setup teamviewer to give you remote access if you want
i can pm you the details ??
heres a note i prepared earlier
box and dropbox are giving side by side errors on boot
what action please
i still have to install the brother ql-570 drivewrs and p-touch s/w
ok to proceed
a windows update to c++ 2008 was failing - KB2538243, code 643
try again ? when ?
evernote is now broken too
these issues were fixed last week. afaik the QL-570 install was the
problem (maybe not)
can you tell what caused them
how do i avoid these problems in the future
i have windows firewall, avg and malwarebytes....
THANKS
just let me know.
I think I clarified that statement with "usually" in my PM to you....
Anyway, which files are we still missing?
8.0.50727.6195 is located at https://www.microsoft.com/en-us/download/details.aspx?id=26347
and 9.0.21022.8 at Download Microsoft Visual C++ 2008 Redistributable Package (x64) from Official Microsoft Download Center
The latter can be found at Part 1: Troubleshooting VC++ Side by Side Problems - Developer Support Languages - VC++, C# and VB.NET - Site Home - MSDN Blogs
I don't have the kit on me to extract these files or create a fix at the moment - I'll be back later.
Richard
Sorry, Richard I am not clear on whats missing
I am waiting for Alex to get back to me
I was a little concerned about the elapsed time.
The missing files should be listed in the cloud links above.
THANK YOU
jg
hi
my daily backup app has now died giving a 0xc0150002 error on startup
please update me on progress....
thank you
Hi
I have checked the HDD and it seems ok....
The errors that are arising i believe are further knock on of the c++/.net broken files etc
My daily backup has been broken since this started (AOMEI bacckup) i do have an image from 10 days ago
I have been working using web apps other working apps and my linux partition....
i would have to manually find all the files created/modified since the last backup
find a way to copy them
restore from image
copy over the newer files...
we havent tried to fix the issue yet
the nmachine is still working and booting apart from the indicated errors...
please advise what action is the best/quickest/easiest
i await your recommendation/advice
thanks
jeremy
Hello again :)
Can you please drop the following .zip file on top of SFCFix and see if there's any improvement? Please post the logfile. My hope is that this will resolve half of the remaining corruptions. We'll see. I'll put the other half through separately if this goes well.
Richard
