[7 SP1 x64] Help with fixing corrupted files found by SFCFix
meeps715
A few days ago my "Turn Windows features on or off" list stopped showing anything, so I ran SFC & SURT and made sure all windows services were on. SFC found files it could not fix, so I looked more into that and eventually found SFCFix recommended by some people. And now I'm here, I ran it and it found alot of corrupted files and that has now directed me here to look for help. I've attached SFCFix.txt alongside the SURT and CBS logs, any help fixing these files would be greatly appreciated as reinstalling Windows would be very annoying. Thank you all in advance.
Export registry as hive
  • Click on the Start button and in the search box, type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send To -> Compressed (zipped) Folder.
  • If the file is too large to upload here, please upload to Gofile or WeTransfer and just provide the downloadlink here.
Below a first fix.
  2. Download the attachment fixlist.txt and save it to your desktop.
  3. Right-click on FRST64.exe and select "Run as administrator".
  4. Press the Fix button.
  5. The tool will now process fixlist.txt.
  6. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
  7. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
  8. Attach the logfile Fixlog.txt to your next reply.
Is this machine upgraded from Windows Vista ?
It would seem it failed to delete 4 registry entries. I can see them in regedit.exe, should I delete them manually?
Here's SFCFix.txt
Start time: 2024-11-05 16:52:57.593
Using .txt script file at C:\Users\Mia Munson\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Anytime-Upgrade-HomePremium-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-BRCpl-Premium-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Anytime-Upgrade-HomePremium-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Failed to delete registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Anytime-Upgrade-HomePremium-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Failed to delete registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Failed to delete registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-BRCpl-Premium-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Failed to delete registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-BRCpl-Premium-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Anytime-Upgrade-HomePremium-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Backup-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-Branding-HomePremium-Client-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Microsoft-Windows-BRCpl-Premium-LanguagePack-Package~31bf3856ad364e35~amd64~de-DE~6.0.6000.16386.
RegistryScript:: directive failed to complete successfully.
Currently storing 53 datablocks.
Finish time: 2024-11-05 16:52:57.874
Script hash: g6O8t4l0Ak4o5Sgw9sg8iEZoVsEMCLneSI6c9QgL7rI=
No.
Looks good.
  3. Press the Fix button.
