[SOLVED] [7SP1 x64] KB4074598 Fails with Error 0x80004005
(cont) I did install security compliance manager 4.0 ; sql server 2008; i was running into some issues re-installing these programs later; there was some residual sql server data left behind on the machine as they never uninstalled correctly; Now when I try reinstall it i get this message:
Checking Security Compliance Manager Installation Prerequisite...
Node - DEVICE
ERROR:
Description = Server execution failed
Installing Microsoft Visual C++ 2010 x86 Redistributable - 10.0.30319
Hello again!
If you would like for me to assist you further you have to follow my instructions and not make any changes to the system without consulting me first, because that makes it very difficult for me to diagnose and ultimately fix the issue you are experiencing. If you feel there are more things to be done on your own end without me assisting you, you can do that.
Just let me know.
0x80004005 means "permission denied", so whoever was trying to install bits didn't have the permissions to do so. You would need to become "owner" or otherwise have such permissions. You can look at the properties of the directory to determine the owner and the security restrictions on it.
I did run a bunch of commands I had found online to reset trusted installers permissions; im thinking ill do that again;
Binance is crashing; looking at the log it says "System.ComponentModel.Win32Exception (0x80004005): Error creating window handle. at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)"
Solved, 2 months later! After 3 dist upgrades and jumping through HOOPS!
So I finally solved this Windows / Update BUG, it and it was as simple as this; set peerdissvc (aka branchcache as it is known under services.msc) from disabled back to manual, along with its dependency http, to manual. I'm quite sure setting branchcache to manual was all that was necessary for the fix to take place; I also had set "not configured" to alll changes I had made to "Background Intelligence Transfer Service" under group policy regarding peer caching. I had tried the latter before the last 3 distupgrades and it did not make any difference; so it seems windows update fails if you disable branchcache, which is typically only used by businesses anyway, so many people recommend to disable it, for security reasons also. What a headache; I spent at least a 80 hours, and weeks, and months trying to figure this one out; Windows update has turned into a bunch of bull***** with their ROLLUPS; one error on one of 130 little updates and the whole shebang goes down with the ship; dumbest idea ever for their update platform; they should change to individual updates and do it quick.
This is a MICROSOFT WINDOWS UPDATE BUG. You shouldn't have to enable or disable any built in windows service to get a "windows" update working. What a headache.
SO for all of you 80004005 victims out there; know very well whatever app is failing to install, be it IIS as quoted above -> they disabled IIS and it fixed their problem, or peerdist -> I set it to manual, or anything else, make sure you fiddle with enabling or disabling the service using services.msc or under the registry HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\
Change the entry "start" typically to demand or auto, or disable if it was already enabled.
0 Boot
1 system
2 Automatic
3 Demand (aka manual)
4 Disabled
Here is how another user solved this issue:
For me the problem resides with peerdist; I had already disabled it under services and its dependency "http" after the dist upgrade and updating windows.
Another user claimed the following:
I can also attest that IIS seemed to be the culprit for me.
I disabled the services World Wide Web Publishing Service, IIS Admin Service and some others for good measure, set them all to manual, rebooted, then tried to install SP1 RC Refresh and that finally succeeded.​
I would get certain GUIDs in my CBS.log:
Code Block
2008-01-17 12:28:30, Error CSI 00000d42 (F) Failed execution of queue item Installer: Task Scheduler ({386b5911-b69e-4d2d-a3ab-796d2ec6af38}) with HRESULT 80041315 [Error,Facility=FACILITY_ITF,Code=4885 (0x1315)]. Failure will not be ignored: A rollback will be initiated after all the operations in the installer queue are completed; installer is reliable (2)[gle=0x80004005]
Old component: Microsoft-Windows-IIS-HttpErrors, Version = 6.0.6000.16386, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
New component: Microsoft-Windows-IIS-HttpErrors, Version = 6.0.6001.17128, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
CSIPERF:AIDONE;{81a34a10-4256-436a-89d6-794b97ca407c};Microsoft-Windows-IIS-HttpErrors, Version = 6.0.6001.17128, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral;274
2008-01-17 12:28:41, Error CSI 00000f12 (F) Done with generic command 110 (0x0000006e); CreateProcess returned 0, CPAW returned S_OK
Url reservation add failed, Error: 6
check your C:\Windows\Logs\CBS\cbs.log; search for "error" or "Failed execution" know very well whatever app is failing to install, try find it in services as mentioned above. enable or disable it depending on what it was set to before, or whatever you want; then reboot, then try the update.
