Thank you so much
xrobwx71,
FreeBooter and
Digerati for your posts and for being so kind to assist me. All my fans are setup to run constantly being active. Never had problems with overheating. I was just concerned that the mentioned short 5 second run/stop/run at boot time can damage the motherboard in same way. But you explained it perfectly.
If I may, I would have two other question. I posted them on other forums but did get conflicting advises, like change the power supply, reset BIOS/flash, change wires/cables. This applies to my second question. 1: I also replaced years ago a CPU fan, purchased a high quality expensive one. runs just fine, no issues, no overheating. My Dell PC has a option in BIOS to run hardware test upon boot, I run it few times, and it reports an error with CPU fan, however I have never had any problems with it. CPU has not been overheating, and is cooled well. The fan has a wire with 3 pins, and I have it on the motherboard there is a 4 pin connector for CPU fan. So I have it on right side, leaving 1 pin open on left. I do not want to keep changing it because the fan runs perfectly fine and cooling CPU with proper speed. Can I ignore it? Perhaps the old fan had wire with 4 pins...
2: For the last 2 months, I purchased 3 new internal mechanical hard drives, WD Black Performance/gaming 1 TB. I run Western Digital Dashboard's long test and reported no errors. Also running Hard Disk Sentinel to monitor Smart values. I installed them each separately, only intend to have 1 hard drive in my PC. Reading SMART values, on each of them the spin up time is going up and since the value 3 has to do with motor/bearing troubles I would like to know if that is normal for a new hard drive. I have a time window open to return the drives, but if those are fine, I just keep them. I am attaching a screenshot of the SMART values as well as voltages from PSU for possible consideration of examining them.
Thank you for being so kind and willing to assist/help/advise me if my PC is stable in these regards mentioned above.
Respectfully,
Johan
