No I'm not.Are you using bitlocker?
Hi sorry for the slow reply. I've found that disabling DOCP (XMP) on my RAM completely eliminates the issue. I assume I've got faulty ram, as this is my second motherboard now in trying to sort these issues.Try to disable AMD PSP device in device manager and reboot.
Or it isn't faulty at all, but its compatibility wasn't tested by the manufacturers... In fact, it works on your system and four RAM tests didn't show issues.Hi sorry for the slow reply. I've found that disabling DOCP (XMP) on my RAM completely eliminates the issue. I assume I've got faulty ram, as this is my second motherboard now in trying to sort these issues.
Lots of other people are using this RAM absolutely fine with the board. I'm not getting ram errors, but I am getting really bad latency when testing. I think I'm going to ask around and see if other people use the exact same kit and see what their experience is.Or it isn't faulty at all, but its compatibility wasn't tested by the manufacturers... In fact, it works on your system and four RAM tests didn't show issues.
Maybe you can try other settings for it (if it's possibile).
The simpler solution would be to use a RAM kit in MB QVL (but even then, other problems may appear).
