@xrobwx71 So at these spikes i definitely heard some crackles while playing league of legends and a stream on in the background, the crackles happened from discord, very slight but i heard it.
CONCLUSION
LatencyMon has been analyzing your system for 0:48:28 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: CHRISTIAN
OS version: Windows 10, 10.0, version 2009, build: 19044 (x64)
Hardware: System Product Name, ASUS
BIOS: 2004
CPU: GenuineIntel Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 16300 MB total
CPU SPEED
Reported CPU speed (WMI): 360 MHz
Reported CPU speed (registry): 360 MHz
Highest measured interrupt to process latency (µs): 4625.80
Average measured interrupt to process latency (µs): 5.699670
Highest measured interrupt to DPC latency (µs): 4621.90
Average measured interrupt to DPC latency (µs): 3.149136
REPORTED ISRs
Highest ISR routine execution time (µs): 633.761111
Highest reported total ISR routine time (%): 0.155510
Total time spent in ISRs (%) 0.171126
ISR count (execution time <250 µs): 7541865
ISR count (execution time 500-1000 µs): 16
REPORTED DPCs
Highest DPC routine execution time (µs): 5191.188333
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0.054524
Total time spent in DPCs (%) 0.155024
DPC count (execution time <250 µs): 18679362
DPC count (execution time 500-10000 µs): 56
DPC count (execution time 1000-2000 µs): 4
DPC count (execution time 2000-4000 µs): 4
DPC count (execution time >=4000 µs): 4
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 24202
Hard pagefault count of hardest hit process: 6355
Number of processes hit: 124
PER CPU DATA
CPU 0 Interrupt cycle time (s): 198.315808
CPU 0 ISR highest execution time (µs): 633.761111
CPU 0 ISR total execution time (s): 79.270566
CPU 0 ISR count: 6982896
CPU 0 DPC highest execution time (µs): 4204.744444
CPU 0 DPC total execution time (s): 60.309155
CPU 0 DPC count: 16404673
CPU 1 Interrupt cycle time (s): 53.008220
CPU 1 ISR highest execution time (µs): 55.522778
CPU 1 ISR total execution time (s): 0.359653
CPU 1 ISR count: 558471
CPU 1 DPC highest execution time (µs): 300.033333
CPU 1 DPC total execution time (s): 7.314471
CPU 1 DPC count: 663526
CPU 2 Interrupt cycle time (s): 36.150402
CPU 2 ISR highest execution time (µs): 2.7650
CPU 2 ISR total execution time (s): 0.000373
CPU 2 ISR count: 514
CPU 2 DPC highest execution time (µs): 315.976667
CPU 2 DPC total execution time (s): 2.554990
CPU 2 DPC count: 869197
CPU 3 Interrupt cycle time (s): 24.092618
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 70.081667
CPU 3 DPC total execution time (s): 0.030979
CPU 3 DPC count: 11187
CPU 4 Interrupt cycle time (s): 32.070519
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 4787.088889
CPU 4 DPC total execution time (s): 0.301158
CPU 4 DPC count: 122974
CPU 5 Interrupt cycle time (s): 27.988494
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 116.406667
CPU 5 DPC total execution time (s): 0.076186
CPU 5 DPC count: 13770
CPU 6 Interrupt cycle time (s): 35.291803
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 298.897778
CPU 6 DPC total execution time (s): 0.603487
CPU 6 DPC count: 310755
CPU 7 Interrupt cycle time (s): 21.947227
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 2554.367778
CPU 7 DPC total execution time (s): 0.025602
CPU 7 DPC count: 8000
CPU 8 Interrupt cycle time (s): 27.050413
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 144.082222
CPU 8 DPC total execution time (s): 0.206901
CPU 8 DPC count: 73568
CPU 9 Interrupt cycle time (s): 23.185942
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 71.077778
CPU 9 DPC total execution time (s): 0.016262
CPU 9 DPC count: 5907
CPU 10 Interrupt cycle time (s): 30.48750
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 2550.261111
CPU 10 DPC total execution time (s): 0.200745
CPU 10 DPC count: 77006
CPU 11 Interrupt cycle time (s): 22.118083
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 79.600556
CPU 11 DPC total execution time (s): 0.047002
CPU 11 DPC count: 18181
CPU 12 Interrupt cycle time (s): 23.823304
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 5191.188333
CPU 12 DPC total execution time (s): 0.135142
CPU 12 DPC count: 36401
CPU 13 Interrupt cycle time (s): 18.872306
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 294.103333
CPU 13 DPC total execution time (s): 0.044327
CPU 13 DPC count: 13206
CPU 14 Interrupt cycle time (s): 29.275993
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 1577.801111
CPU 14 DPC total execution time (s): 0.080283
CPU 14 DPC count: 20903
CPU 15 Interrupt cycle time (s): 30.686764
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 296.228333
CPU 15 DPC total execution time (s): 0.190996
CPU 15 DPC count: 30176
