secondcat
- Jan 15, 2025
- 2
Therein lies your problem. You cannot take the HDD from one system and boot it on a different system. When Windows is installed it configures itself for the hardware platform it's being installed onto, it also (as you've seen) installs all the necessary drivers for that platform (inc. chipset drivers, which will vary from platform to platform) and any necessary updates, some of which are platform specific. I rather suspect that you have done way more than corrupt the registry, you will likely have several different chipset drivers installed, updates for different platforms, and drivers for devices that only exist on one platform and not the others. In short you have royally screwed-up your Windows installation on that HDD by booting it on many different platforms.Subsequently, I connected the HDD directly to the motherboard, and it booted successfully. Windows started installing drivers and other necessary software onto the hard drive. After that, I kind of started messing around and connected the hdd to different computers I own, sometimes using and not using the adapter. Unfortunately, after some time of messing around and windows 10 displays the 'bad system config info' bsod. I tried boot into various computers with the same error. Even when I connected to the original laptop it displays the same error.
