I've decided it is time to get a new battery for my Acer netbook. Unfortunately, the chain where I purchased a battery for my husband's Aspire 722, doesn't carry any for my model. (V5-131-2629). There are lots of V5 models and quite a few that start out with V5-131.
I went searching by battery part number yesterday knowing the volts, mAh and Wh of what I have and double checking on Acer's site by entering my SNID.
I found two possible replacements. Both are the exact voltage I need: 11.1V.
Neither is the correct mAh. My current battery is 5000 mAh.
One replacement is 5200 mAh and the other is 4400 mAh.
Obviously I don't want a lower mAh battery because the run time would be lower.
Finally my questions: Will I hurt the netbook by using a battery that has a slightly higher mAh than the original?
I should have thought to do this before I posted my question.
I ended up calling the battery chain and asking the above question. I was told it will not hurt my netbook if I use a higher mAh battery than the OEM one.
