Not to take away from Harry's post, because I am sure he has a few things to chime in on in addition to what I may find...
CLOCK_WATCHDOG_TIMEOUT (101)
This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
BugCheck 101, {[COLOR=#ff0000]60[/COLOR], 0, [COLOR=#4b0082]807c5120[/COLOR], 1}
^^ 60 clock ticks in regards to the timeout.
0: kd> !prcb 1
PRCB for Processor 1 at [COLOR=#4b0082]807c5120[/COLOR]:
Current IRQL -- 0
Threads-- Current 8519bd48 Next 85140958 Idle 807ca800
Processor Index 1 Number (0, 1) GroupSetMember 2
Interrupt Count -- 00034cdd
Times -- Dpc 00000058 Interrupt 00000048
Kernel 000020aa User 000004b9
As this matches the 3rd parameter of the bug check, processor #1 is the responsible processor. Now with the information we have here thus far, we know that processor #1 reached 60 clock ticks without responding, therefore the system crashed. Before we go further, what is a clock tick? A clock interrupt is a form of interrupt which involves counting the the cycles of the processor core, which is running a clock on the processors to keep them all in sync. A clock interrupt is handed out to all processors and then they must report in, and when one doesn't report in, you then crash.
0: kd> kv
ChildEBP RetAddr Args to Child
90a738e4 82a82a1f 00000101 00000060 00000000 nt!KeBugCheckEx+0x1e
90a73920 82a8206e 00002626 00000000 00002700 nt!KeAccumulateTicks+0x242
90a73960 82a81f1b 82a3ec5e 4b40880d 00000000 nt!KeUpdateRunTime+0x145
90a739b8 82a86bb7 0000041b 0000041b 000000d1 nt!KeUpdateSystemTime+0x613
90a739b8 82a3ec5e 0000041b 0000041b 000000d1 nt!KeUpdateSystemTimeAssist+0x13 (FPO: [0,2] TrapFrame @ [COLOR=#ff0000]90a739cc[/COLOR])
90a73a5c 82ab91a7 a7cdf000 00000000 90a73aac nt!KeFlushMultipleRangeTb+0x2d5
90a73b3c 82aa5ca9 c053e700 00000008 00000000 nt!MiFlushTbAsNeeded+0x12e
90a73b7c 82b26487 00027cd8 00000001 84f79000 nt!MiAllocatePagedPoolPages+0x567
90a73be0 82aa260d 00000001 00008000 00000ff0 nt!MiAllocatePoolPages+0x1f
90a73c38 82b27132 00000000 00000001 00008000 nt!ExpAllocateBigPool+0xa6
90a73c9c 82aaeb89 00000001 00008000 20207050 nt!ExAllocatePoolWithTag+0x12d
90a73cc0 82beb8c9 86d80630 00008000 20207050 nt!ExAllocatePoolWithQuotaTag+0x57
90a73cf0 82beb6b6 00000009 a2462f88 00000018 nt!PiControlGetInterfaceDeviceList+0x86
90a73d20 82a4527a 00000009 0149f5d0 00000018 nt!NtPlugPlayControl+0xbe
90a73d20 775170b4 00000009 0149f5d0 00000018 nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 90a73d34)
WARNING: Frame IP not in any known module. Following frames may be wrong.
0149f608 00000000 00000000 00000000 00000000 0x775170b4
0: kd> .trap 90a739cc
ErrCode = 00000000
eax=00000002 ebx=00000001 ecx=a7cdf000 edx=00000000 esi=d7b9f00e edi=82b3358c
[COLOR=#ff0000]eip=82a3ec5e [/COLOR]esp=90a73a40 ebp=90a73a5c iopl=0 nv up ei ng nz na po nc
cs=0008 ss=0010 ds=0000 es=0001 fs=0fff gs=8f07 efl=00000282
[COLOR=#4b0082]nt!KeFlushMultipleRangeTb+0x2d5[/COLOR]:
[COLOR=#ff0000]82a3ec5e [/COLOR]8b07 mov eax,dword ptr [edi] ds:82b3358c=00000002
0: kd> u @eip
nt!KeFlushMultipleRangeTb+0x2d5:
82a3ec5e 8b07 mov eax,dword ptr [edi]
82a3ec60 85c0 test eax,eax
82a3ec62 75de jne nt!KeFlushMultipleRangeTb+0x2b9 ([COLOR=#ff0000]82a3ec42[/COLOR])
[COLOR=#4b0082]82a3ec64[/COLOR] 8a4d0f mov cl,byte ptr [ebp+0Fh]
82a3ec67 ff155881a082 call dword ptr [nt!_imp_KfLowerIrql (82a08158)]
82a3ec6d 5f pop edi
82a3ec6e 5e pop esi
82a3ec6f 5b pop ebx
0: kd> u 82a3ec42 82a3ec64
nt!KeFlushMultipleRangeTb+0x2b9:
82a3ec42 46 inc esi
82a3ec43 8535c40bb782 test dword ptr [nt!HvlLongSpinCountMask (82b70bc4)],esi
82a3ec49 7511 [COLOR=#ff0000]jne[/COLOR] [COLOR=#ff0000]nt!KeFlushMultipleRangeTb+0x2d3[/COLOR] (82a3ec5c) [COLOR=#ff8c00]<--- Takes the jump (jmp) to stay in a loop.[/COLOR]
82a3ec4b f605bc0bb78240 test byte ptr [nt!HvlEnlightenments (82b70bbc)],40h
82a3ec52 7408 [COLOR=#ff0000]je[/COLOR] [COLOR=#ff0000]nt!KeFlushMultipleRangeTb+0x2d3[/COLOR] (82a3ec5c)
82a3ec54 56 push esi
82a3ec55 e865080a00 call nt!HvlNotifyLongSpinWait (82adf4bf)
82a3ec5a eb02 [COLOR=#ff0000]jmp[/COLOR] [COLOR=#ff0000]nt!KeFlushMultipleRangeTb+0x2d5[/COLOR] (82a3ec5e)
82a3ec5c f390 [COLOR=#4b0082]pause[/COLOR] [COLOR=#ff8c00]<--- Executing a pause (a CPU delay), and doing this in a loop waiting for a release.[/COLOR]
82a3ec60 85c0 [COLOR=#4b0082]test eax,eax[/COLOR] [COLOR=#ff8c00]<--- Checking if value is non-zero.[/COLOR]
82a3ec62 75de [COLOR=#ff0000]jne[/COLOR] [COLOR=#ff0000]nt!KeFlushMultipleRangeTb+0x2b9[/COLOR] (82a3ec42)
82a3ec64 8a4d0f mov cl,byte ptr [ebp+0Fh]
Okay, so what's causing the loop? We'll need to dump the other call stacks to try and get an idea.
0: kd> ~1
WARNING: Process directory table base AEAC25A0 doesn't match CR3 00185000
1: kd> kv
00000000 00000000 00000000 00000000 00000000 0x0
Okay, so here we have the problematic processor, which is all zeroed out, plus the process directory table doesn't match. We'll need to dump the raw stack.
1: kd> !pcr
KPCR for Processor 1 at 807c5000:
Major 1 Minor 1
NtTib.ExceptionList: 9efb3b60
NtTib.StackBase: 00000000
NtTib.StackLimit: 00000000
NtTib.SubSystemTib: 807c8750
NtTib.Version: 0006ce50
NtTib.UserPointer: 00000002
NtTib.SelfTib: 7ffdf000
SelfPcr: 807c5000
Prcb: 807c5120
Irql: 00000000
IRR: 00000000
IDR: ffffffff
InterruptMode: 00000000
IDT: 807ce020
GDT: 807cdc20
TSS: 807c8750
[COLOR=#ff0000] CurrentThread: 8519bd48[/COLOR]
NextThread: 85140958
IdleThread: 807ca800
DpcQueue: 0x807c8520 0x82afaf0f [Normal] nt!PpmPerfAction
1: kd> !thread
THREAD [COLOR=#ff0000]8519bd48 [/COLOR]Cid 0f80.0f28 Teb: 7ffdf000 Win32Thread: fe98c9c0 RUNNING on processor 1
Not impersonating
DeviceMap 8bfa1470
Owning Process 851afd40 Image: Isaac.exe
Attached Process N/A Image: N/A
Wait Start TickCount 9687 Ticks: 401 (0:00:00:06.265)
Context Switch Count 18083 IdealProcessor: 0
UserTime 00:00:13.578
KernelTime 00:00:02.000
Win32 Start Address 0x00b657f0
Stack Init 9ee17fd0 Current 9ee17bc8 Base [COLOR=#0000cd]9ee18000 [/COLOR]Limit [COLOR=#4b0082]9ee15000 [/COLOR]Call 500
Priority 12 BasePriority 8 UnusualBoost 0 ForegroundBoost 2 IoPriority 2 PagePriority 5
9ee1640c 82a894c0 nt!SepSidInTokenSidHash+0x40
9ee16410 9ee166a8
9ee16414 010954b8
9ee16418 00000000
9ee1641c 9ee16438
9ee16420 82a89476 nt!SepSidInToken+0x29
9ee16424 00000000
9ee16428 00000000
9ee16434 860954b0
9ee16438 9ee16464
9ee1643c 82a89279 nt!SepNormalAccessCheck+0x6c
9ee16440 00000000
9ee16464 9ee1650c
9ee16468 82a88eba nt!SepAccessCheck+0x1f9
9ee1646c 00000001
9ee16484 9ee1650c
9ee16488 82a88f05 nt!SepAccessCheck+0x244
9ee1648c 82a8916b nt!SepAccessCheck+0x4a8
9ee16490 9ee169f8
9ee16494 9ee165d0
9ee16498 82a89202 nt!SepAccessCheck+0x539
9ee1649c 8201916b
9ee1650c 9ee16574
9ee16510 82a88c74 nt!SeAccessCheckWithHint+0x1f1
9ee16514 86095494
9ee16568 00000003
9ee1656c 82a9e700 nt!RtlpPopulateContext+0xa
9ee16570 9ee165e0
9ee16574 9ee169ac
9ee16578 82a9ea99 nt!SeAccessCheckFromState+0xea
9ee1657c 01095494
9ee165ac 00000000
9ee165b0 82a9eaaa nt!SeAccessCheckFromState+0xfb
9ee17058 82e24615 hal!HalpGetPmTimerPerfCounterValue+0x29
9ee1705c 00000508
9ee17070 9ee17080
9ee17074 82e24b8c hal!HalpPmTimerQueryPerformanceCounter+0x42
9ee17078 86cd0000
9ee17088 ffffff00
9ee1708c 91781b51 dxgmms1!VidSchiUpdateContextRunningTimeAtISR+0x69
9ee17090 e069d700
9ee170ac 9ee17104
9ee170b0 91783735 dxgmms1!VidSchiProcessIsrCompletedPacket+0x1d5
9ee170b4 00000008
9ee170c8 9ee17104
9ee170cc 86cd09d0
9ee170d0 91783744 dxgmms1!VidSchiProcessIsrCompletedPacket+0x1e4
9ee170d4 86cc4008
9ee170d8 86cd0000
9ee17100 00000000
9ee17104 9ee17134
9ee17108 91785952 dxgmms1!VidSchDdiNotifyInterruptWorker+0x1b2
9ee1710c 86cc4008
9ee17128 86447000
9ee1712c 91471728*** ERROR: Symbol file could not be found. Defaulted to export symbols for nvlddmkm.sys -
nvlddmkm!nvDumpConfig+0x1d6a60
9ee17130 00000000
9ee17134 9ee17198
9ee17138 90cd0434 nvlddmkm+0x97434
I didn't dump the entire raw stack, but there were also some network related routines. Right, so interrupts aren't processed on a separate stack, and is generally delivered on the existing stack (as we can see above). However, before the DPC queue is drained, it swaps to a dedicated stack specific for DPC processing. I believe this may be because the CPU is
so behind at this current time.
1: kd> !dpcs
CPU Type KDPC Function
1: Normal : 0x807c8520 0x82afaf0f nt!PpmPerfAction
We can confirm that it is very behind by checking whether or not we have any pending DPCs, which we do. Not good at all to
ever have any pending DPCs.
1. Ensure you have the latest video card drivers. If you are already on the latest video card drivers, uninstall and install a version or a few versions behind the latest to ensure it's not a latest driver only issue. If you have already experimented with the latest video card driver and many previous versions, please give the beta driver for your card a try.
2.
0: kd> lmvm VSTCNXT3
start end module name
8f228000 8f2dd000 VSTCNXT3 (deferred)
Image path: \SystemRoot\system32\DRIVERS\VSTCNXT3.SYS
Image name: VSTCNXT3.SYS
Timestamp: Wed Oct 15 17:29:13 [COLOR=#ff0000]2008[/COLOR]
^^ Conexant SoftK56 Modem driver. Once you reach I'd say Windows 7, these device drivers just don't behave properly at
all. I recommend replacing this modem and purchasing a more up-to-date method of connecting to the internet ASAP. It
might be contributing to the problem here given the network routines in the raw stack.
3. If the above do not help, I am going to go ahead and say this is a faulty processor.
Regards,
Patrick
