[SOLVED] Bsod from graphics card
In all this time no one pointed out that there was a disk drive problem. But all my files have been Removed from the computer before packaging it up.
That being said any way to figure out which hard drive that was, I have the nvme drive an an external ssd
I had a laptop I was able to plug the external drive in, I ran windows 10 error check on it and it found issues, so I would assume that would be the drive having issues then.
Running a check disk on the drive now
The drive has errors and corruption and check disk says it can't fix it, due to not enough space to fix bad clusters.
