Lurizan
Active member
- Jan 10, 2022
- 41
- A brief description of your problem (but you can also include the steps you tried)
- System Manufacturer?-HUAWEI
- Laptop or Desktop?-LAPTOP
- Exact model number (if laptop, check label on bottom)-BoH-WAQ9R
- OS ? (Windows 11, 10, 8.1, 8, 7, Vista)-WINDOWS 10
- x86 (32bit) or x64 (64bit)?-64BIT
- (Only for Vista, Windows 7) Service pack?
- What was original installed OS on system?-WINDOWS 10
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?-OEM
- Age of system? (hardware)3-4
- Age of OS installation?3-4
- Have you re-installed the OS?-NO
- CPU-AMD RYZEN 5
- RAM (brand, EXACT model, what slots are you using?)-4GB HYNIX HMA851S6CJR6N-VK CHANNEL A. 4GB HYNIX HMA851S6CJR6N-VK CHANNEL B
- Video Card-RADEON VEGA 8
- Is driver verifier enabled or disabled?-DISABLED
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)-MCAFEE
- Are you using proxy, vpn, ipfilters or similar software?-NO
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)-NO
- Are you currently under/overclocking? Are there overclocking software installed on your system?-NO
