Hello,
A member in
this thread referred me to create a post here to troubleshoot BSODs. As I mentioned in that thread, I haven't experienced any BSODs since I replaced RAM. However, according to the logs, the responder pointed out that post-RAM swap crashes have occurred.
- A brief description of your problem (but you can also include the steps you tried)
The original cause of the issues was that Windows updates took multiple hours, resulting in a forced reboot during upgrades. Subsequent system instability ensued, as Windows updates failed to install, BSODs, and DSIM and SFC failed to repair the system.
HP
Desktop
- Exact model number (if laptop, check label on bottom)
OMEN by HP Obelisk Desktop 875-1040st CTO
- OS ? (Windows 11, 10, 8.1, 8, 7, Vista)
Windows 10 22H2
- x86 (32bit) or x64 (64bit)?
x64
- What was original installed OS on system?
Windows 10 Home
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
OEM
- Age of system? (hardware)
Built to order, received in January of 2020
Uncertain
- Have you re-installed the OS?
I'm not sure if I reinstalled the OS or cloned my drive when I moved to a new system drive.
i7-9700K
- RAM (brand, EXACT model, what slots are you using?)
G.SKILL, F4-3600C16D-32GVKC, all four slots.
NVIDIA RTX2070 Super
HP OEM
HP 750W
- Is driver verifier enabled or disabled?
Disabled (I think - verifier /querysettings shows no flags enabled)
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)
Built-in Windows Tools
- Are you using proxy, vpn, ipfilters or similar software?
Windows built-in and Tailscale
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)
No
- Are you currently under/overclocking? Are there overclocking software installed on your system?
I think the HP OC tools are running a profile that isn't standard, but it's been a while since I've even looked at them.
Speccy Snapshot
