BSODs usually when idle they are random.
This was the last blue screen I got
123120-10046-01.dmp 12/31/2020 3:41:20 AM ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY 0x000000fc fffff806`3586c120 89000000`0656c963 fffff806`3586bf90 00000000`00000000 Wdf01000.sys Wdf01000.sys+97eb8 Kernel Mode Driver Framework Runtime Microsoft® Windows® Operating System Microsoft Corporation 1.31.19041.1 (WinBuild.160101.0800) x64 ntoskrnl.exe+3f5210 C:\Windows\Minidump\123120-10046-01.dmp 8 15 19041 2,171,572 12/31/2020 12:32:05 PM
Did iobit thing.
I attached three pngs because I had to scroll down to show everything and am gonna reboot.
You could upload that dump too.
Re-try to remove ene.sys (enetechio is its service name) and all wireless adapter drivers:
sc config enetechio start= disabled
sc stop enetechio
sc delete enetechio
sc delete rtwlane
sc delete rtwlane01
sc stop rtwlane02
sc delete rtwlane02
CMD output :
Microsoft Windows [Version 10.0.19041.630]
(c) 2020 Microsoft Corporation. All rights reserved.
C:\Windows\system32>sc stop enetechio
SERVICE_NAME: enetechio
TYPE : 1 KERNEL_DRIVER
STATE : 1 STOPPED
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
C:\Windows\system32>sc config enetechio start= disabled
[SC] ChangeServiceConfig SUCCESS
C:\Windows\system32>sc delete enetechio
[SC] DeleteService SUCCESS
C:\Windows\system32>sc delete rtwlane
C:\Windows\system32>sc delete rtwlane01
C:\Windows\system32>sc stop rtwlane02
[SC] OpenService FAILED 1060:
The specified service does not exist as an installed service.
C:\Windows\system32>sc delete rtwlane02
I also attached dumps, I think, Thanks again too
Now, these last five BSODs are interesting.
I see often in your dumps (even previous ones): xboxgip.sys, usbxhci.sys, spacedeskKtmInputMouse.sys, dc-1controller.sys, gameflt.sys.
I suspect you have a problem with that mouse (spacedesk) while you are using the xbox?
Or a device attached to a USB 3/3.1/3.2 port...
What devices are you using and where are they attached?
I suspect also gigabyte aorus software (and its two drivers): are you using it?
By the way, let's see if newer BSODs will appear after the changes we made today.
Some windbg output:
Im using in this order a keyboard, mouse, and xbox controller plugged into the usb 3.0 ports on my mobo, however the keyboard an mouse are new and I was getting blue screens well before they were there. I use the xbox controller to plug my headset into, because thats the only way I can get my mic to work because its a headset meant for xbox. Sorry for such a late response I typed this out but never actually sent it lol. And yeah I am using gigabytes rgbfusion I think
Nvlddmkm.sys was a misbehaving driver seen in the raw stack.
Bugcheck code 000000FC
Arguments fffff806`3586c120 89000000`0656c963 fffff806`3586bf90 00000000`00000000
Debug session time: Thu Dec 31 02:41:20.447 2020 (UTC - 6:00)
nvlddmkm.sys Fri Dec 11 16:16:51 2020 (5FD40BF3)
Earlier in the thread the Nvidia GPU driver was clean installed using DDU.
The computer has an integrated AMD GPU with switchable graphics:
Processor AMD Ryzen 5 3400G with Radeon Vega Graphics, 3700 Mhz, 4 Core(s), 8 Logical Processor(s)
Please modify the settings so that the AMD integrated (iGPU) is enabled and the Nvidia designated (dGPU) is disabled.
Update the AMD iGPU drivers:
http://support.amd.com/en-us
Temporarily remove the GPU card.
Temp2_SysnativeFileCollectionApp (11).zip\123120-10046-01.dmp
fffff806`3586c558  fffff806`3586c5f8
fffff806`3586c560  ffff848f`40f3f3a0
fffff806`3586c568  fffff806`3586c768
fffff806`3586c570  fffff806`3586c5f9
fffff806`3586c578  fffff806`41a820e6 USBXHCI!Isoch_ProcessTransferEventWithED1+0x1d6
fffff806`3586c580  fffff806`3586c768
fffff806`3586c588  ffff848f`40ef4400
fffff806`3586c590  fffff806`00000040
fffff806`3586c598  00000000`00000001
fffff806`3586c5a0  fffff806`3586c668
fffff806`3586c5a8  fffff806`3586c678
fffff806`3586c5b0  00000000`00000000
fffff806`3586c5b8  fffff806`2ea4129b WppRecorder!WppAutoLogTrace+0x16b
fffff806`3586c5c0  00000000`00000000
fffff806`3586c5c8  fffff806`3de3fe10 dxgkrnl!DpGlobals+0x410
fffff806`3586c5d0  00000000`00000002
fffff806`3586c5d8  fffff806`429a9db7Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_a51067c0ac557884\nvlddmkm.sys, Win32 error 0n2
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
nvlddmkm+0x819db7
fffff806`3586c5e0  fffff806`00000040
fffff806`3586c5e8  fffff806`3586c6e0
fffff806`3586c5f0  ffff848f`40f3f430
fffff806`3586c5f8  fffff806`3586c5f8
fffff806`3586c600  fffff806`3586c5f8
fffff806`3586c608  00000000`0000002b
fffff806`3586c610  ffff848f`388475f0
fffff806`3586c618  ffff848f`380feb10
fffff806`3586c620  00000000`0000000c
fffff806`3586c628  ffff848f`39144950
fffff806`3586c630  00000000`000004c0
fffff806`3586c638  fffff806`3586c768
fffff806`3586c640  ffff848f`388475f0
fffff806`3586c648  ffff848f`40ef3a30
fffff806`3586c650  fffff806`3586c789
fffff806`3586c658  fffff806`41a81ef0 USBXHCI!Isoch_EP_TransferEventHandler+0x10
fffff806`3586c660  fffff806`3586c700
fffff806`3586c668  fffff806`3586c700
fffff806`3586c670  00000000`00000000
fffff806`3586c678  fffff806`00000000
fffff806`3586c680  fffff806`41a81ee0 USBXHCI!Isoch_EP_TransferEventHandler
fffff806`3586c688  fffff806`41a86570 USBXHCI!Endpoint_TransferEventHandler+0xb0
fffff806`3586c690  00000000`00000004
fffff806`3586c698  fffff806`3586c738
fffff806`3586c6a0  00000000`00000008
fffff806`3586c6a8  fffff806`3586c740
fffff806`3586c6b0  00000000`00000004
fffff806`3586c6b8  fffff806`3586c748
fffff806`3586c6c0  00000000`00000004
fffff806`3586c6c8  fffff806`3586c750
fffff806`3586c6d0  00000000`00000004
fffff806`3586c6d8  00000000`00000000
fffff806`3586c6e0  ffff848f`39144880
fffff806`3586c6e8  fffff806`41a860a5 USBXHCI!Interrupter_DeferredWorkProcessor+0x315
fffff806`3586c6f0  00000000`00000780
fffff806`3586c6f8  00007b70`c6ba4400
fffff806`3586c700  ffff848f`388475f0
fffff806`3586c708  ffff848f`393428e0
Driver    C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY\NV_DISPI.INF_AMD64_A51067C0AC557884\NVLDDMKM.SYS (27.21.14.6089, 32.60 MB (34,188,528 bytes), 12/30/2020 11:48 PM)
For any BSOD:
a) run the Sysnative log collector to collect new log files
b) open file explorer> this PC > C: > in the right upper corner search for: C:\Windows\memory.dmp
> if the file size is < 1.5 GB then zip > post a separate share link into the thread using one drive, drop box, or google drive
I still haven't gotten a blue screen since the other day and my PC has been on the whole time, I think I'm going to wait and see if I'm getting more blue screens before making any changes again.
I have started getting blue screens again. I attached the dump files. But could you clarify what im supposed to do with igpu and dgpu? Do I remove my gpu then update the drivers, or do I disable it then update igpu drivers then remove my gpu? Thanks in advance
There were 5 new BSOD mini dump files.
The bugchecks were:
7E
1E
50
A
EF
1) When available update the thread with Memtest86 results: 2 tests with 4 passes each
2) If possible use only Ethernet
3) Turn off wireless (hardware / mechanical off if available)
4) Uninstall rtwlane02.sys
5) Uninstall Vbox software
6) Make sure VBoxNetLwf.sys is uninstalled
7) There may be settings in the BIOS for iGPU and dGPU.
8) Turn on AMD iGPU
9) Update AMD iGPU drivers
10) Turn off Nvidia dGPU
11) Remove Nvidia GPU card
12) Use DDU to uninstall Nvidia GPU drivers
13) If there are BSOD after completing all of the above steps:
a) open file explorer> this PC > C: > in the right upper corner search for: C:\Windows\memory.dmp
> if the file size is < 1.5 GB then > save to the downloads folder > zip > post a separate share link into the thread using one drive, drop box, or google drive
b) Place the computer into safe mode (shift + restart):
Boot into Safe Mode on Windows 10
Name    [00000001] TP-Link Wireless PCI Express Adapter
Adapter Type    Ethernet 802.3
Product Type    TP-Link Wireless PCI Express Adapter
Installed    Yes
PNP Device ID    PCI\VEN_10EC&DEV_8812&SUBSYS_820310EC&REV_01\001288FEFF4CE00000
Last Reset    1/2/2021 1:28 AM
Index    1
Service Name    RTWlanE
IP Address    192.168.1.10, fe80::4c6b:462f:1e13:a2f9
IP Subnet    255.255.255.0, 64
Default IP Gateway    192.168.1.1
DHCP Enabled    Yes
DHCP Server    192.168.1.1
DHCP Lease Expires    1/3/2021 1:28 AM
DHCP Lease Obtained    1/2/2021 1:28 AM
MAC Address    ‪98:48:27:44:53:53‬
I/O Port    0x0000DF00-0x0000DFFF
Memory Address    0xF76FC000-0xF76FFFFF
IRQ Channel    IRQ 4294967262
Driver    C:\WINDOWS\SYSTEM32\DRIVERS\RTWLANE02.SYS (2024.0.4.208, 9.19 MB (9,634,008 bytes), 12/16/2020 2:52 PM)
rtwlane02    Realtek Wireless LAN 802.11n PCI-E Network Adapter    c:\windows\system32\drivers\rtwlane02.sys    Kernel Driver    Yes    Manual    Running    OK    Normal    No    Yes
RTWlanE02    Realtek Wireless LAN 8 Realtek Wireless LAN 8 Kernel        Manual     Running    OK         TRUE        FALSE        4,096             4,255,744   0          5/26/2019 3:58:52 AM   C:\Windows\system32\drivers\rtwlane02.sys        8,192
VBoxNetLwf   VirtualBox NDIS6 Bridg VirtualBox NDIS6 Bridg Kernel        System     Running    OK         TRUE        FALSE        0                 122,880     0          10/16/2020 11:33:18 AM C:\Windows\system32\DRIVERS\VBoxNetLwf.sys       4,096
rtwlane02.sys Sun May 26 00:58:52 2019 (5CEA473C)
VBoxNetLwf.sys Fri Oct 16 08:33:18 2020 (5F89BD3E)
