X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 20, 2024 #1 I have already installed the 2 updates needed for KB4534310 (KB4490628 ; KB4474419), the automatic updater for Win7 keeps failing, and after trying it with DISM I got the error code 80070002. This update has apparently been failing to download since January of last year I believe through the automatic updater. Similarly, update KB4524157 also fails to install, as well as the optional updates KB2830477 and KB2592687, but I am unsure if these are related. Sfcscan tells me there are no issues, as well as ComponentsScanner. Link for the CBS folder: CBS.zip Attachments ComponentsScanner.txt 706 bytes · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 20, 2024 #2 Hello and welcome, Please do following. Install Update with DISM Download the update MSU here: https://catalog.s.download.windowsu..._4dc78a6eeb14e2eac1ede7381f4a93658c8e2cdc.msu Copy the MSU file to a convenient location (such as C:\temp). Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different expand windows6.1-kb4534310-x64_4dc78a6eeb14e2eac1ede7381f4a93658c8e2cdc.msu -f:* C:\temp DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 20, 2024 #3 Hello and thank you for the response Peter, as expected DISM fails again at 66% with the error code 0x80070002 (the screenshot is in German and if need be I could translate). I have attached the CBS log file. Attachments CBS.zip 546.5 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 20, 2024 #4 Great. The error is logged. No need to translate, I can read German text. Provide the Components Hive 1. Navigate to C:\Windows\System32\Config and locate the COMPONENTS file. 2. Please copy this file to your desktop. Note: If you receive an error that this file is in-use, simply reboot your computer and try again. Note: If you find that you need to reboot and are unable to because this is a server then try Option#2 below. 3. Right-click on this file on your desktop and select Send To...Compressed (zipped) folder. This will create a file named COMPONENTS.ZIP on your desktop. 4. The file will likely be too large to upload here so please upload to Gofile or WeTransfer and just provide the link here. Option#2 (only if you are unable to follow the previous instructions) Please download the Freeware RegBak from here: Acelogix Software - Download products You will find it at the bottom of the page that the link brings you to. Go ahead and install this program and accept all the defaults. After the last install screen the program should open. Click the New Backup button. Accept the defaults and simply click Start. When it says Finished successfully, click the Close button. This will bring you back to the main screen of the program. You will see one entry in this list with the date that you did it. Right-click on this line-item and select Explore Backup... This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, one of which is named COMPONENTS. Copy the COMPONENTS file to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS. Now right-click on the COMPONENTS file that is on your desktop and select Send to > Compressed (zipped) folder. Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply. You can close any open windows you have as well as the RegBak program now.
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 21, 2024 #5 That's good to know! The link for the components file: components.zip
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 21, 2024 #6 Step 1: Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment and extract it. Open the extracted folder, double-click the file regfix.reg. When prompted allow to change the registry settings. Report the result. Step 2: Install Update with DISM again Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log Attachments regfix.zip 493 bytes · Views: 2
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 21, 2024 #7 The registry edit worked fine, however the installation using DISM fails again at 66% with the same error code as before. The CBS log is attached. Attachments CBS.zip 286.3 KB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 21, 2024 #8 Another fix is needed. Step 1: Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment and extract it. Open the extracted folder, double-click the file regfix2.reg. When prompted allow to change the registry settings. Report the result. Step 2: Install Update with DISM again Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log Attachments regfix2.zip 441 bytes · Views: 1
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 22, 2024 #9 Registry edit once again worked fine, however installation fails at the same spot again. The CBS log is attached. Attachments CBS.zip 8.3 MB · Views: 1
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 22, 2024 #10 Next fix. Step 1: Warning: This script was written specifically for this user, for use on that particular machine. Do not run this script on another machine. Download the attachment and extract it. Open the extracted folder, double-click the file regfix3.reg. When prompted allow to change the registry settings. Report the result. Step 2: Install Update with DISM again Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log Attachments regfix3.zip 439 bytes · Views: 1
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 22, 2024 #11 Registry edit worked, however the installation still fails at the same spot, with the same error code. The CBS log is attached. Attachments CBS.zip 7.7 MB · Views: 2
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 22, 2024 #12 The issues seem to be related to a particular update. Lets remove that one. Remove Update Manually Click on the Start button and in the search box, type Command Prompt. When you see Command Prompt on the list, right-click on it and select Run as administrator. When command prompt opens, copy and paste the following command into it, then press enter. wusa /uninstall /KB:4015549 Let me know if it says it was successful or if there are any errors.
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 22, 2024 #13 The update in question uninstalled successfully.
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 22, 2024 #14 Great. Install Update with DISM again Click on the Start button and in the search box, type Command Prompt When you see Command Prompt on the list, right-click on it and select Run as administrator When command prompt opens, copy and paste the following commands into it, press enter after each cd C:\temp replace C:\temp with your path if different DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab You should receive the message: The operation completed successfully. Make sure to allow the computer to restart if prompted. If you receive any other message: Post a screenshot of the Commandprompt window. Zip and attach the file C:\Windows\Logs\CBS\CBS.log
X Xeraph Member Joined Jun 20, 2024 Posts 8 Jun 23, 2024 #15 Seems that KB4015549 was the issue, as KB4534310 now installed successfully. Thank you for your help!
P PeterJ Moderator, Windows Update Expert, Security Analyst Staff member Joined Dec 14, 2014 Posts 13,480 Jun 23, 2024 #16 Great. I will mark this thread as solved. You may remove the fixes and log files used in this thread to cleanup. Take care.
