[SOLVED] Can't update, dism and sfc fails
wow
Active member
France
Hi sysnative !
Some times ago my computer didnt wanted to boot I had to replace some (Maybe corrupted ?) files by clean one from another pc.
Now I can't do the Updates, they fails.
I've tried the Dism, SFC and SFCFix tools.
SFCFix:
No problems found.
SFC:
"La vérification 6% est terminée.La protection des ressources Windows n’a pas réussi à effectuer l’opération demandée."
"The 6% verification is complete.
Windows resource protection failed to perform the requested operation."
DISM:
Le pilote WOF a rencontré une défaillance dans la Table des ressources du fichier compressé.
The WOF driver has encountered a failure in the Resource Table of the compressed file.
Notes: The errors are translated with Google Translate, And sorry for my english wich is pretty bad :)
Thank you !
2018-07-05 15:07:59, Error                 CSI    00000007 (F) c000a2a7 [Error,Facility=(system),Code=41639 (0xa2a7)] #183872# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = 4d8 ('\Device\HarddiskVolume5\Windows\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0xf7a71fb200, data = {l:0 b:}, byteoffset = 0, key = (null))
[gle=0xd000a2a7]
2018-07-05 15:07:59, Error                 CSI    00000008@2018/7/5:13:07:59.638 (F) onecore\base\wcp\sil\ntsystem.cpp(3533): Error c000a2a7 [Error,Facility=(system),Code=41639 (0xa2a7)] originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile expression: (null)
[gle=0x80004005]
Let's start by checking disk health.
GSmartControl
  • Extract the content of the GSmartControl .zip archive and execute gsmartcontrol.exe; To extract you can right-click your mouse on the GSmartControl.zip file and select Extract.
  • Also, go in the Attributes tab and if you have any entries highlighted in red or pink, copy and paste their name in your next reply (or take a screenshot of the GSmartControl window and attach it in your next reply);
Please make sure to back up any important data on this drive before continuing.
chkdsk /f
  1. Click on the Start
    chkdsk /f
  4. Reboot
  5. Download ListChkdskResult.exe (by SleepyDude) from the link below:
  6. Double click on it to run it. It will take a few seconds to scan, then it will open a Notepad window with the log. Copy and paste the contents of this into your next post please!
View attachment SFCFix.zip
DISM /RestoreHealth Scan
  1. Right-click on the Start
  3. This will create a file, cbs.txt on your Desktop. Please zip and attach this to your next post.
If the zip file is larger than 8MB, please use a file sharing service such as OneDrive, DropBox, SendSpace, etc. and include the link with your reply.
Hi, Thanks for your fast response !
Here is the SFCfix log:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-07-09 22:41:27.428
Microsoft Windows 10 Build 17134 - amd64
Using .zip script file at C:\Users\wow\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui
Failed to backup file C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui with error code 0x1160.
Successfully copied file C:\Users\wow\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui to C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui.
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.81_pt-pt_bfbe9b18b3a127ca\bootmgr.exe.mui
Finish time: 2018-07-09 22:41:28.906
Script hash: fdIjvB9ozkHYLO2CNMlMUn7YJqkxyW3IhM8MPRNYk+M=
For the DISM process i've got a new error at 10% (8% before)
Error: 605
The specified buffer contains badly formed data.
Logs: http://access.mywow.cf:3000/llSK.zip
I'm getting a connection timeout trying to download the logs.
Would you mind trying something like SendSpace or DropBox?
If the zip is less than 8MB it can be attached with your reply :)
2018-07-09 22:43:55, Info                  CBS    FLOW: Entering stage: CheckCsi
2018-07-09 22:44:41, Info                  CSI    00000007 Hashes for file member [l:18]'POSyncServices.dll' do not match.
 Expected: {l:32 ml:4096 b:24f3870303fb3e468e43fd5eb396a40415d10305cbbc735f336c47d3f63d237a}.
 Actual: {l:33 ml:4096 b:d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34d34}.
2018-07-09 22:44:50, Error                 CSI    00000008 (F) c0000242 [Error,Facility=(system),Code=578 (0x0242)] #326850# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = 59c ('\Device\HarddiskVolume5\Windows\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0xb85297b040, data = {l:0 b:}, byteoffset = 0, key = (null))
[gle=0xd0000242]
2018-07-09 22:44:50, Error                 CSI    00000009@2018/7/9:20:44:50.897 (F) onecore\base\wcp\sil\ntsystem.cpp(3533): Error c0000242 [Error,Facility=(system),Code=578 (0x0242)] originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile expression: (null)
[gle=0x80004005]
I'll come back to this, most likely sometime tomorrow :)
Here is the SFCFix logs:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-07-11 19:13:03.362
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui
Failed to backup file C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui with error code 0x25D.
Successfully copied file C:\Users\wow\AppData\Local\niemiro\Archive\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui to C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui.
Successfully restored ownership for C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui
Successfully restored permissions on C:\WINDOWS\WinSxS\x86_microsoft-windows-b..ager-pcat.resources_31bf3856ad364e35_10.0.17134.48_tr-tr_4b1e2a8c7ea0913d\bootmgr.exe.mui
Finish time: 2018-07-11 19:13:04.352
Script hash: dTGyn6rf2zWd9lDKxhZsu/yYnatok9Jg31R7wU8x2EM=
The dism crashed at 16% with the 605 error
Error: 605
(Translated error)
https://www.sendspace.com/file/16wu5l
Thanks !
2018-07-11 19:15:20, Info                  CSI    00000007 Hashes for file member [l:18]'POSyncServices.dll' do not match.
2018-07-11 19:16:18, Error                 CSI    00000008 (F) c0000242 [Error,Facility=(system),Code=578 (0x0242)] #679335# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = 52c ('\Device\HarddiskVolume5\Windows\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0x1f4e07b5b0, data = {l:0 b:}, byteoffset = 0, key = (null))
[gle=0xd0000242]
2018-07-11 19:16:18, Error                 CSI    00000009@2018/7/11:17:16:18.617 (F) onecore\base\wcp\sil\ntsystem.cpp(3533): Error c0000242 [Error,Facility=(system),Code=578 (0x0242)] originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile expression: (null)
[gle=0x80004005]
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-07-11 19:45:59.048
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll
Failed to backup file C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll with error code 0x25D.
Successfully copied file C:\Users\wow\AppData\Local\niemiro\Archive\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll to C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll.
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbx3w81.dll
Finish time: 2018-07-11 19:45:59.764
Script hash: fvLrPuAbmeQMWcXFE7j6mLopLo050F2fba0sqEWq7V0=
For the DISM i've got the same error (Same error code,same %)
Download cbs.txt from Sendspace.com - send big files the easy way
Thanks ! :)
2018-07-11 19:47:10, Error                 CSI    00000008 (F) c0000242 [Error,Facility=(system),Code=578 (0x0242)] #679362# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = 588 ('\Device\HarddiskVolume5\Windows\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0xd0b757b4f0, data = {l:0 b:}, byteoffset = 0, key = (null))
[gle=0xd0000242]
2018-07-11 19:47:10, Error                 CSI    00000009@2018/7/11:17:47:10.198 (F) onecore\base\wcp\sil\ntsystem.cpp(3533): Error c0000242 [Error,Facility=(system),Code=578 (0x0242)] originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile expression: (null)
[gle=0x80004005]
SFCLogs:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-07-11 20:14:37.347
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll
Failed to backup file C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll with error code 0x25D.
Successfully copied file C:\Users\wow\AppData\Local\niemiro\Archive\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll to C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll.
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbxpsrender.dll
Finish time: 2018-07-11 20:14:38.428
Script hash: sKage0AUJc6PNh2/G/NOJ3kzFucWVAgPtX0xUX01t10=
Here is the Dism log (Same error)
Looks like there are pending repairs from SFC. Please restart the computer before continuing :)
2018-07-11 20:16:46, Error                 CSI    00000681 (F) c0000242 [Error,Facility=(system),Code=578 (0x0242)] #7514252# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = e60 ('\Device\HarddiskVolume5\Windows\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0x26a297b530, data = {l:0 b:}, byteoffset = 0, key = (null))
[gle=0xd0000242]
2018-07-11 20:16:46, Error                 CSI    00000682@2018/7/11:18:16:46.224 (F) onecore\base\wcp\sil\ntsystem.cpp(3533): Error c0000242 [Error,Facility=(system),Code=578 (0x0242)] originated in function Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile expression: (null)
[gle=0x80004005]
Okay, I restarted my pc
Here is the SFCFix log:
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-07-11 20:57:49.070
Successfully took permissions for file or folder C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll
Failed to backup file C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll with error code 0x25D.
Successfully copied file C:\Users\wow\AppData\Local\niemiro\Archive\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll to C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll.
Successfully restored ownership for C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll
Successfully restored permissions on C:\WINDOWS\WinSxS\amd64_dual_prnhpcl1.inf_31bf3856ad364e35_10.0.17134.1_none_44cc5b011bfb70d4\amd64\hpbresw81.dll
Finish time: 2018-07-11 20:57:49.453
Script hash: mQ6zgh13STUPtuDW3vtmAYxG+B+YCjI0b5gyYMyrXOQ=
The cbs.txt:
2018-07-11 20:59:50, Error CSI 00000008 (F) c0000242 [Error,Facility=(system),Code=578 (0x0242)] #685313# from Windows::Rtl::SystemImplementation::DirectFileSystemProvider::SysReadFile(h = 5ac ('\Device\HarddiskVolume5\Windows\WinSxS\amd64_dual_prnms002.inf_31bf3856ad364e35_10.0.17134.1_none_d305185132a94aea\Amd64\FXSWZRD.DLL'), evt = 0, apcr = NULL, apcc = NULL, iosb = @0x48f567af60, data = {l:0 b:}, byteoffset = 0, key = (null))
Have some improvements
The FXSWZRD.DLL is corrupt, in the same folder FXSTIFF.DLL is too (Have an error when trying to get the hash with 7zip)
