[SOLVED] Corrupt files and can't fix them
Sorry, i just read the instructions now. Here's the SFCFix log file. I tried to attach CBS folder but i think it didn't work
Start time: 2015-09-15 11:49:52.772
Finish time: 2015-09-15 11:50:33.412
DISM /RestoreHealth Scan
  1. Right-click on the Start
  3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post:
    C:\Windows\Logs\CBS\CBS.log
(p)	CSI Payload Corrupt	(Fixed)	amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB
Summary:
Operation: Detect and Repair
Operation result: 0x0
Last Successful Step: Entire operation completes.
Total Detected Corruption:	1
	CBS Manifest Corruption:	0
	CBS Metadata Corruption:	0
	CSI Manifest Corruption:	0
	CSI Metadata Corruption:	0
	CSI Payload Corruption:	1
Total Repaired Corruption:	1
	CBS Manifest Repaired:	0
	CSI Manifest Repaired:	0
	CSI Payload Repaired:	1
	CSI Store Metadata refreshed:	True
Total Operation Time: 1935 seconds.
Looks like DISM fixed it.
If you run SFC now it should report that no corruptions were detected.
Summary:
You mean sfc /scannow?
Yes :)
SFC Scan
  1. Swipe in from the right edge of the screen, and then tap Search.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
  2. Type cmd in the search box, and then right-click or press and hold on Command Prompt.
  3. Tap or click Run as administrator.
  4. When command prompt opens, copy and paste the following commands into it, press enter after each
  5. This will create a file, cbs.txt on your Desktop. Please attach this to your next post.
Let's try this:
Run Windows Repairs
  1. Download Windows Repair (All-in-One) Portable to your desktop.
  2. Once the file is downloaded, right-click on the file on your desktop and choose Extract All...
  3. Keep the defaults and click the Extract button.
  4. A folder named tweaking.com_windows_repair_aio will be extracted to the desktop. Once the extraction is complete the folder will open.
  5. Inside this folder, there is a folder named Tweaking.com - Windows Repair. Open this folder as well.
  6. Double-click on Repair_Windows.exe to open. Note: Please make sure all of your programs are closed and anything you were working on is saved as we will be rebooting.
  7. When the program opens, click the Reboot to Safe Mode button at the bottom of the screen. Answer Yes to allow.
  8. Once rebooted into Safe Mode, open the program again. When the program opens, click the Repairs tab and click the Open Repairs button.
  9. A backup of your registry will be made. After a few moments you will have many options from which you can choose.
  10. Please click the Unselect All button and then click to enable only the following ones:
    28.01 - Repair Windows 8/10 App Store
  11. Ensure the Restart check box is selected and click the Start Repairs button in the lower right of the screen. This may take some time to run so be patient.
  12. Once the fixes are complete you will be prompted to restart your machine. Answer Yes.
Let's try this:
Run Windows Repairs
OMG!!! Can't believe it worked! Thank you so much for helping me out :)
Glad to hear it!
I'll mark the thread solved. If you encounter further problems, please post back and I will continue to assist you.
