[SOLVED] Corrupt Files
I ran sfc and found corrupt files that sfc could not fix.Then I ran sfcfix and there was some files that could not be fixed automatically.I realize these files are not necessary for windows,but I can't get sfc to run clean without fixing them.I hope someone can help.My operating system is Windows 7 Home Premium x64 Bit.I will attach CBS logs and SFCFIX logs.
Thanks so much for your help,it looks like everything was fixed.You guys no your stuff.I can't tell you how much I appreciate what you did Peter.And here is the Logs.
Many Blessings
whiteowl65
Great. The log looks good. Please run the command SFC /SCANNOW again and report the result.
Here is the CBS Logs you requested.If you think everything looks good,I have another question for you later about CHKDSK results,showing USA Check Value.If I need to post that in another Forum please let me know.
The attachment contains the file sfcdetails.txt which is useless. If the SFC scan reported no violations were found the cbs.log is not needed.
What exactly do you mean ?
Provide an example when available.
Yes the sfc scan said windows resource protection found no integrity violations.Here is the CBS Logs again.I don't know what happened last time.As for my question about CHKDSK,I will have to run it again and post back.
Many Blessings
whiteowl65
Good. All is done.
We 'll wait for the CHKDSK result.
Peter,here is the CHKDSK results,I am wondering what the USA Check Values are,no one seems to have a clue what they mean or what is causing them.They have been showing up for a while now.If anyone there can shed some light on this I would be grateful.They don't seem to be causing any problems on the machine.Windows 7 Home Premium(x64) SP 1.And when windows finishes checking, It says It found no problems.Very strange to me.
Your welcome. I will mark this thread as solved.
Take care.
