[SOLVED] CSB errors | Problems installing CU update
Remy
Well-known member
Hello Sysnative Support,
I got a problem with one of my systems. The problem is an error after running "DISM /Online /Cleanup-image /Scanhealth":
(p) CSI Manifest Corrupt wow64_microsoft-windows-directui.resources_31bf3856ad364e35_10.0.14393.5066_fr-fr_90d1188067c3b330
(w) CBS Package Index Package Missing 0x80070490 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Package Missing 0x80070490 Microsoft-Windows-Client-Features-Package-AutoMerged-onecore~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Package Missing 0x80070490 Microsoft-Windows-Server-Features-Package-AutoMerged-onecore~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Package Missing 0x80070490 Microsoft-Windows-ServerCore-SKU-Foundation-onecore-Package~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Package Missing 0x80070490 Microsoft-Windows-TroubleShooting-onecore-Package~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Package Missing 0x80070490 Product-onecore__Microsoft-OneCore-NetworkDiagnostics-Package~31bf3856ad364e35~amd64~~0.0.0.0 Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
(w) CBS Watchlist Component Missing 0x80070490 amd64_microsoft-windows-n..pture-wmiv2provider_31bf3856ad364e35_0.0.0.0_none_648e5a14f42bfaca Package_3286_for_KB4048953~31bf3856ad364e35~amd64~~10.0.1.3
Summary:
Operation: Detect only
Operation result: 0x0
Last Successful Step: CSI store detection completes.
Total Detected Corruption: 8
CBS Manifest Corruption: 0
CBS Metadata Corruption: 7
CSI Manifest Corruption: 1
CSI Metadata Corruption: 0
CSI Payload Corruption: 0
Total Repaired Corruption: 0
CBS Manifest Repaired: 0
CSI Manifest Repaired: 0
CSI Payload Repaired: 0
CSI Store Metadata refreshed: True
I tried to repair the system with some dism restore commands, but it would not fix the problem. After trying to repair the server be myself, i tried to repair the server with the SFCfix.exe tool. Also this tool could not repair the server. I uploaded the SFCfix.exe log and the CSB folder in the attachment.
Can you guys help me out with this problem?
I hope to here from you soon.
Kind Regards,
Remy
Thanks for the quick reply. See the attacht file for the results.
Regards,
Remy
Please run FRST to remove the warnings related to KB4048953.
Download the
  • Press the Fix button.
Click the Start button and in the search box, type Command Prompt
When you see Command Prompt on the list, right-click on it and select Run as administrator.
When command prompt opens, copy and paste the following command and press enter.
Take a screenshot of the commandprompt window and paste it into your next reply.
This looks good, are there any further problems or is everything working fine now?
Im trying to update the system tonight with the latest Windows Updates and let you know the results.
Thanks for so far!
Regards,
Remy
Goodmorning,
After repairing the system errors the latest CU is succesfully installed, but 1 update keeps failing.
The system is still healthy and has no errors anymore.
Can you help me with this issue?
Regards,
Remy
Open the startmenu and type appwiz.cpl and press enter.
Which versions of Microsoft Visual C++ are installed?
Yes. The system is healthy and the update is completed!
Thanks for helping me in this case!
Kind Regards,
Remy
Your welcome. Glad to here that all the updates installed without any problems...
I'll mark this thread as solved!
