[SOLVED] CSI Manifest Missing 0x00000002 in windows 7 Pro Ultimate 64-bit
Edmundas-PC
86
Dear mister PeterJ!
Please help me with my Windows 7 Ultimate 64-bit errors:"CSI Manifest Missing 0x00000002". Maybe that's why PC sleep doesn't work and the computer works poorly and slow. I would appreciate your help.
Edmundas
Hi @Edmundas-PC,
  • Download
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to Gofile or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply.
All went well.
Restart the machine.
Master Peter.
Forgive the old man for a big, probably irreparable mistake. I didn't notice YOUR new attachment and used the old one, I apologize once again for this behavior. Maybe it wasn't necessary, but I did everything again and sent it as instructed.
No worries. That fix repaired some system files only. Doing that twice should be no problem.
Next fix.
You used an old fix again. Please read the given instructions carefully and always use the attachment in that post.
Perform the instructions in message #7.
Dear Peter!
You must be very busy. You probably don't have jerks like me. Or maybe you
don't want to help me anymore. Yesterday I fell asleep and didn't hear the phone ring.
I just found YOUR post this morning. I'm very sorry. I sent the specified information at about 09:09 AM. I'm ready and I'm sitting at the computer and I'm afraid to step back so I don't miss YOUR follow-up information.
Edmundas
Well done this time. The CheckSur log looks as expected.
None of that. Maybe I'm in a different time zone than you are, and creating a new fix may take some time too.
Please be patient.
Next fix.
Well done. The CheckSur log is clean.
Run the command sfc /scannow in an elevated commandprompt and report the result.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
I did sfc /scannow. The result is excellent: Windows Resource Protection did not find any integrity violations. Very good! However, CBS.log (10.677 kb) does not open: 'Access is denied'. Anyway, it was not possible to archive. Maybe you will open?
If no violations are found I don't need the log file.
Any remaining issues or can we mark this thread as solved ?
Hello!
I don't know how to thank you. One problem remains. I did the rest according to the instructions, but the machine does not want to sleep. But I'll handle it myself. Thanks again for your help.
Edmundas
Your welcome.
I'll mark this thread as solved.
Take care and best wishes for 2025.
