Debugging a Hyper-V VM
Gator
Active member
Ft. Myers
Is it the same as debugging a physical server?
Getting a lot of errors
* Bugcheck Analysis *
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: ffffe000ad824ff0, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80257237f10, address which referenced memory
Debugging Details:
GetContextState failed, 0x80004002
Unable to get current machine context, HRESULT 0x80004002
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
ReadControl failed - kernel symbols must be loaded first
(many of these, removed for length)
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
DUMP_TYPE: 1
BUGCHECK_P1: ffffe000ad824ff0
BUGCHECK_P2: 2
BUGCHECK_P3: 1
BUGCHECK_P4: fffff80257237f10
WRITE_ADDRESS: Target machine operating system not supported
ffffe000ad824ff0
CURRENT_IRQL: 2
FAULTING_IP:
+0
fffff802`57237f10 ?? ???
CPU_COUNT: 6
CPU_MHZ: 0
CPU_VENDOR:
CPU_FAMILY: 0
CPU_MODEL: 0
CPU_STEPPING: 0
DEFAULT_BUCKET_ID: CORRUPT_MODULELIST_AV
BUGCHECK_STR: AV
ANALYSIS_SESSION_HOST: MAURICE-LT
ANALYSIS_SESSION_TIME: 11-14-2019 18:02:44.0497
ANALYSIS_VERSION: 10.0.16299.91 amd64fre
IP_IN_FREE_BLOCK: 0
STACK_TEXT:
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
STACK_COMMAND: .thread ; .cxr ; kb
PRIMARY_PROBLEM_CLASS: CORRUPT_MODULELIST_AV
FAILURE_BUCKET_ID: CORRUPT_MODULELIST_AV
TARGET_TIME: 2019-11-14T21:08:54.000Z
OSBUILD: 9600
OSSERVICEPACK: 0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 16
PRODUCT_TYPE: 3
OSPLATFORM_TYPE: x64
OSNAME: Windows 8.1
OSEDITION: Windows 8.1 Server TerminalServer
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: unknown_date
ANALYSIS_SESSION_ELAPSED_TIME: 1c
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:corrupt_modulelist_av
FAILURE_ID_HASH: {fc259191-ef0c-6215-476f-d32e5dcaf1b7}
Followup: MachineOwner
WARNING: Unable to reset page directories
Normally I'd do that but this is for a client on a production server. I'm just curious about debugging a Hyper V server and whether or not it's the same as debugging a physical server. Also, I have WinDBG 10.0.16299.91 -- is that ok for Server 08 R2 - Build 7601 (Hyper-V VM)?
