Odd, there might have been remains of the incompatible software in the registry somewhere; I'm not completely sure.
I would continue to use the system as you usually would for a few days and see if it remains stable.
found out one thing, aicharger by asus, even the latest version (2018) which effectively increases charging power to usb devices, by detecting if a device is charge capable, causes keyboard, mouse and other devices to stop functioning when booting; I suspect this has to do with the IMMOU virtualization protection changing DMA addresses, the aicharger buggers everything; seems to happen during boot as well, lights go off on devices and stay off, its automatically installed as "demand start"
Do you have the latest BIOS installed for your motherboard?
I also understand that once you install Windows with CSM enabled, you can't go back and disable CSM later and therefore: no Secure Boot.
amdppm!WriteIoMemRawEx+0x70
amdppm!WriteGenAddrEx+0x6b
amdppm!WriteGenAddrMaybeHiddenEx+0x18
I'm going to test a fresh install to see if its a software issue, then restore after
MSDTC started with the following settings:
Security Configuration (OFF = 0 and ON = 1):
Allow Remote Administrator = 0,
Network Clients = 0,
Transaction Manager Communication:
Allow Inbound Transactions = 0,
Allow Outbound Transactions = 0,
Transaction Internet Protocol (TIP) = 0,
Enable XA Transactions = 0,
Enable SNA LU 6.2 Transactions = 1,
MSDTC Communications Security = Mutual Authentication Required,
Account = NT AUTHORITY\NetworkService,
Firewall Exclusion Detected = 0
Transaction Bridge Installed = 0
Filtering Duplicate Events = 1
The trigger appeared to be enabling remote connections in DCOM temporarily for DCOM troubleshooting, but DCOM is unable to communicate with MSDTC, does this not render dcom completely ineffective? I suspect it is not running because I had disabled DCOM prior to running windows updates and dist-upgrades... given that, I am unsure if DCOM is even capable of functioning at all.
The trigger... I enabled DCOM, and remote access defaults in DCOM and immediately ran gmer, in case WMI/DCOM unleashed hidden malware, and sure enough that is when gmer detected MBR rookkit activity, followed by the password screen which appeared upon reboot, and is technically disabled at logon.The trigger for the error message? Did you complete a fresh install of Windows? You mentioned that you might do one in your earlier post.
I turned off CSM and did not have to re-install Windows, it started without problems
