[SOLVED] directX and Nvidia drivers causing high DPC? FIX: DISABLED ONBOARD GRAPHICS CARD
chef
I am largely a PC newbie, but will try to include as much detail as I can: I recently put together my first water cooled PC, and have been experiencing audio drop-outs, pops, and occasionally lag and drops in FPS during gaming. For the most part, the audio problem arises when streaming online, particularly when opening a new window or other program or when the video is loading. Im running an ethernet cable and generally get 200-250Mbps (most recent speedtest: http://www.speedtest.net/result/7079366170.png), so I dont think its the connection. Recently, audio has begun to drop out while gaming too, and I have to go to the realtek audio manager and disable then enable the device to get it to turn back on. Im using a Samsung 4k TV through an HDMI cable as my monitor, the problem is not in the speakers themselves, they're fine when using the tv directly (via netflix, amazon, or other in-TV programs).
high DPC latency seems to be common so here are some of the things I have tried (and have been unsuccessful with) while checking with latencymon:
changed XMP profiles
disabled all audio drivers and ran one at a time
revert to an old NVIDIA driver with clean install (388)
reinstall current NVIDIA driver w/o any other drivers (audio, 3d, phsyx, etc)
update BIOS (both to latest, then to slightly older version to avoid buggy chipset fix)
ran MEMTEST (no issues found)
tried running audio directly from mobo instead of GPU
turned off mobo audio in bios
updated all drivers w/ iobit driver booster
disabled avast/malwarebytes
disabled network adapter drivers
I have not tried:
messing with C states in bios
enabling driver verifier
starting w/o gpu or trying different pcie slots
I would not be surprised if Im just doing something stupid or have something activated/deactivated that shouldnt be... this build has been a learning process, but Im floored that anyone would need to jump through this many hoops and spend all this $ on a product that doesnt work 100% :frown6:
here are the some of the stats, if Im missing anything let me know:
View attachment Dxdiag and msinfo.zip
System Manufacturer? custom build, gigabyte mobo
Laptop or Desktop? desktop
Exact model number (if laptop, check label on bottom) custom build, Z370 AORUS Gaming 7
OS ? (Windows 10, 8.1, 8, 7, Vista) windows 10 education
x86 (32bit) or x64 (64bit)? 64
Service pack? version 1709 os build 16299.248
What was original installed OS on system? win10
Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer) downloaded win10 education from my graduate program
Age of system? (hardware) <2mo
Age of OS installation?<2mo
Have you re-installed the OS? no
CPU i7-8700 CPU @ 3.20GHz, 3192 Mhz, 6 Core(s), 12 Logical Processor(s)
RAM (brand, EXACT model, what slots are you using?) G.SKILL TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) slots 1 & 2
Video Card EVGA GeForce GTX 1080 SC GAMING ACX 3.0 8GB (PCIE 16 slot)
MotherBoard - (if NOT a laptop) Z370 AORUS Gaming 7
Power Supply - brand & wattage (if laptop, skip this one) EVGA SuperNOVA 850 G2 gold fully modular
Is driver verifier enabled or disabled? disabled
What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) avast (subscription), malwarebytes (subscription)
Are you using proxy, vpn, ipfilters or similar software? no
Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
Are you currently under/overclocking? Are there overclocking software installed on your system? unsure, I havent changed settings on overclocking but the system comes w/ OC software
speccy:
http://speccy.piriform.com/results/BTEdoVend3bCU3Th8GZaCOY
latencymon: directx and nvidia drivers seem to be the most frequent, but the audio driver (HDAudBus.sys) also pops up occasionally
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:09:54 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-P70NNJI
OS version: Windows 10 , 10.0, build: 16299 (x64)
Hardware: Z370 AORUS Gaming 7, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz
Logical processors: 12
Processor groups: 1
RAM: 16324 MB total
CPU SPEED
Reported CPU speed: 3192 MHz
Highest measured interrupt to process latency (µs): 2041.904434
Average measured interrupt to process latency (µs): 2.823943
Highest measured interrupt to DPC latency (µs): 2004.370606
Average measured interrupt to DPC latency (µs): 1.037430
REPORTED ISRs
Highest ISR routine execution time (µs): 7988.860589
Highest reported total ISR routine time (%): 0.050738
Total time spent in ISRs (%) 0.070014
ISR count (execution time <250 µs): 791133
ISR count (execution time 500-999 µs): 2
ISR count (execution time 1000-1999 µs): 2
ISR count (execution time 2000-3999 µs): 6
REPORTED DPCs
Highest DPC routine execution time (µs): 2071.619987
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 390.77 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.063345
Driver with highest DPC total execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in DPCs (%) 0.154278
DPC count (execution time <250 µs): 3118159
DPC count (execution time 500-999 µs): 4
DPC count (execution time 2000-3999 µs): 1
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0.0
Total time spent in hard pagefaults (%): 0.0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 31.297240
CPU 0 ISR highest execution time (µs): 7988.860589
CPU 0 ISR total execution time (s): 4.701764
CPU 0 ISR count: 762886
CPU 0 DPC highest execution time (µs): 2071.619987
CPU 0 DPC total execution time (s): 9.957578
CPU 0 DPC count: 2920029
CPU 1 Interrupt cycle time (s): 20.686349
CPU 1 ISR highest execution time (µs): 312.879073
CPU 1 ISR total execution time (s): 0.282474
CPU 1 ISR count: 26750
CPU 1 DPC highest execution time (µs): 251.178258
CPU 1 DPC total execution time (s): 0.237026
CPU 1 DPC count: 33208
CPU 2 Interrupt cycle time (s): 13.462427
CPU 2 ISR highest execution time (µs): 147.276942
CPU 2 ISR total execution time (s): 0.006359
CPU 2 ISR count: 1265
CPU 2 DPC highest execution time (µs): 221.937030
CPU 2 DPC total execution time (s): 0.164342
CPU 2 DPC count: 28707
CPU 3 Interrupt cycle time (s): 18.593873
CPU 3 ISR highest execution time (µs): 4.694236
CPU 3 ISR total execution time (s): 0.000292
CPU 3 ISR count: 245
CPU 3 DPC highest execution time (µs): 1045.019424
CPU 3 DPC total execution time (s): 0.039973
CPU 3 DPC count: 10108
CPU 4 Interrupt cycle time (s): 13.223486
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 221.952694
CPU 4 DPC total execution time (s): 0.10930
CPU 4 DPC count: 20123
CPU 5 Interrupt cycle time (s): 18.718043
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 221.932957
CPU 5 DPC total execution time (s): 0.036749
CPU 5 DPC count: 11434
CPU 6 Interrupt cycle time (s): 12.509621
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 204.926065
CPU 6 DPC total execution time (s): 0.109660
CPU 6 DPC count: 22394
CPU 7 Interrupt cycle time (s): 18.072546
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 205.038534
CPU 7 DPC total execution time (s): 0.033162
CPU 7 DPC count: 11208
CPU 8 Interrupt cycle time (s): 12.556901
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 238.710213
CPU 8 DPC total execution time (s): 0.117922
CPU 8 DPC count: 22340
CPU 9 Interrupt cycle time (s): 18.241317
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 204.864348
CPU 9 DPC total execution time (s): 0.025231
CPU 9 DPC count: 6824
CPU 10 Interrupt cycle time (s): 13.330755
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 204.649749
CPU 10 DPC total execution time (s): 0.132306
CPU 10 DPC count: 24509
CPU 11 Interrupt cycle time (s): 18.908270
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 204.739348
CPU 11 DPC total execution time (s): 0.034263
CPU 11 DPC count: 7281
Re: completely stumped, directX and Nvidia drivers causing high DPC?
The thing we're missing from the posting instructions is the Sysnative reports. This includes the crash dumps, event viewer and other info. That would sure help if you would upload it. Thanks.
ah, ok
see attached for the zip
There weren't any dump files produced. The errors in the event viewer all point to Malwarebytes. Please make sure you are running the latest version. You can use the Check For Updates in the program itself. If that doesn't help you can uninstall it then redownload it and reinstall it.
Hi chef,
:welcome: to Sysnative.
Could you please follow steps E and F of POSTING INSTRUCTIONS for DPC/ISR latency, stuttering, cracks/pops, the trace file is the only thing that's missing :smile9:
ok! ill give this a go when i get home, thanks!
definitely running the newest version, will also try an uninstall/reinstall. thanks!
OK, so the SDK trace was too big to attach (10mb), but here's a drive link:
trace2-22.zip - Google Drive
let me know if that doesnt work. It looks like chrome comes up the most in the trace, but the latency issue pops up even w/ firefox and when playing steam games. maybe a complete chrome uninstall is necessary?
also, uninstalled malwarebytes, no fix. I also booted in IGFX instead of the GPU and the latency was still there, AND it went BSOD once as well...that hadnt happened with the GPU as of yet
here was the latencymon run while in IGFX
CONCLUSION
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:02:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Processor groups: 1
RAM: 16252 MB total
CPU SPEED
Highest measured interrupt to process latency (µs): 4111.714682
Average measured interrupt to process latency (µs): 2.451645
Highest measured interrupt to DPC latency (µs): 4105.298649
Average measured interrupt to DPC latency (µs): 0.799114
REPORTED ISRs
Highest ISR routine execution time (µs): 52.670739
Driver with highest ISR routine execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total ISR routine time (%): 0.017255
Driver with highest ISR total time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in ISRs (%) 0.019302
ISR count (execution time <250 µs): 152300
REPORTED DPCs
Highest DPC routine execution time (µs): 292.948935
Highest reported total DPC routine time (%): 0.109830
Total time spent in DPCs (%) 0.172261
DPC count (execution time <250 µs): 544850
DPC count (execution time 500-999 µs): 3
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.868058
CPU 0 ISR highest execution time (µs): 52.670739
CPU 0 ISR total execution time (s): 0.277501
CPU 0 ISR count: 151856
CPU 0 DPC highest execution time (µs): 292.948935
CPU 0 DPC total execution time (s): 1.151470
CPU 0 DPC count: 400157
CPU 1 Interrupt cycle time (s): 1.498416
CPU 1 ISR highest execution time (µs): 15.651629
CPU 1 ISR total execution time (s): 0.000790
CPU 1 ISR count: 373
CPU 1 DPC highest execution time (µs): 134.700188
CPU 1 DPC total execution time (s): 0.03330
CPU 1 DPC count: 6379
CPU 2 Interrupt cycle time (s): 2.436868
CPU 2 ISR highest execution time (µs): 4.104010
CPU 2 ISR total execution time (s): 0.000088
CPU 2 ISR count: 71
CPU 2 DPC highest execution time (µs): 248.330827
CPU 2 DPC total execution time (s): 1.170606
CPU 2 DPC count: 106929
CPU 3 Interrupt cycle time (s): 1.518683
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 127.875627
CPU 3 DPC total execution time (s): 0.007015
CPU 3 DPC count: 2249
CPU 4 Interrupt cycle time (s): 1.281640
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 151.723997
CPU 4 DPC total execution time (s): 0.025304
CPU 4 DPC count: 6110
CPU 5 Interrupt cycle time (s): 1.437799
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 129.876253
CPU 5 DPC total execution time (s): 0.006937
CPU 5 DPC count: 2064
CPU 6 Interrupt cycle time (s): 1.217899
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 153.823308
CPU 6 DPC total execution time (s): 0.017452
CPU 6 DPC count: 4329
CPU 7 Interrupt cycle time (s): 1.491606
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 145.223997
CPU 7 DPC total execution time (s): 0.007875
CPU 7 DPC count: 2245
CPU 8 Interrupt cycle time (s): 1.189493
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 266.442356
CPU 8 DPC total execution time (s): 0.017974
CPU 8 DPC count: 4171
CPU 9 Interrupt cycle time (s): 1.505235
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 122.635652
CPU 9 DPC total execution time (s): 0.010262
CPU 9 DPC count: 2644
CPU 10 Interrupt cycle time (s): 1.207245
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 147.866541
CPU 10 DPC total execution time (s): 0.018879
CPU 10 DPC count: 4255
CPU 11 Interrupt cycle time (s): 1.522785
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 84.782895
CPU 11 DPC total execution time (s): 0.017344
CPU 11 DPC count: 3321
the drive file was a zipped file, so maybe thats why? the dropbox link should work
Windows Performance Kit from Windows Assessment and Deployment Kit needs to be installed to open the trace file properly.
Please revert the driver installs done by Driver Booster and uninstall all programs from IObit, the software of IObit is known for causing issues (especially Advanced SystemCare and Driver Booster) and/or can be replaced with better alternatives.
will do, tho the latency issue showed up before any IObit program installation
He was telling me how to open the file Chef. You don't need to download it. At least I don't think so.
Chef already has the kit installed to provide us the trace file.
@chef, it doesn't matter if the problem started before IObit was installed, there are enough situations where IObit rendered systems unable to boot mainly after using Advanced SystemCare.
ok, do I need to worry about any potential files that arent deleted by the uninstall?
also, any chance this latency stuff is caused by a PCIe riser cable? it still showed up when I booted on IGFX but im curious
Not that I'm aware of. Of course, if there are any problems use either a system restore point or different system backup (if any).
read on another forum that IRQ (conflicts) might be the cause, so checked out my device manager (attached). Any idea why this USB 3.1 controller would be taking up so many slots? also, correct me if im wrong but it seems to be competing with everything else using a PCI? or is IRQ not a concern?
I don't see IRQ data in my device manager, what does msinfo32 say in Hardware Resources > IRQs?
will check when i get home, but to see IRQ in device manager, click the 'view' tab, then sort 'resources by type' and it should be an available tab. My PCI stuff was at the bottom of that list
