[SOLVED] DISM Error: 0x800f081f
Vlads
Hi.
Windows Server 2016 update fails. Security Update for Windows (KB5044293) and 2024-11 Cumulative Update for Windows Server 2016 for x64-based Systems (KB5046612)
DISM utility also fails:
Image Version: 10.0.14393.7426
[=========================100%================================]
Error: 0x800f081f
Thanks for any help
Hi @Vlads,
  • Download
Hello again
Sorry if I'm in a hurry.
After running sfc fix I did a windows update. KB5046612 update was installed successfully and the server rebooted.
After that I checked the health with these results.
C:\Windows\system32>DISM /Online /Cleanup-Image /ScanHealth
Version: 10.0.14393.4169
[==========================100.0%==========================] The component store is repairable.
C:\Windows\system32>sfc /scannow
Verification 100% complete.
So I run ComponentsScanner again and I'm attaching the result.
Thanks in advance for your understanding.
Hrllo
Thanks for the quick response
Result is attached
Checked:
all Ok
You are wizards
Good luck
Reboot the server.
After that run the command
DISM /Online /Cleanup-Image /ScanHealth again and report the result.
Edit: Sorry, I missed the "all Ok".
Thread marked as solved.
Take care.
