P phillywells Member Joined Jul 9, 2015 Posts 7 Jul 10, 2015 #1 So I just happen to run sfc /scannow and it found some errors that it couldn't fix, so I decided to run the DISM tool. I get this error 0x800f0906 and I've made sure that I've enabled component installation and repair in the group policy settings and checked the box next to contact windows update directly beforehand as I see other people doing that with the same problem, so I know that isn't what's wrong. Is there anything I can do to fix these errors?
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 14, 2015 #2 Hi and welcome to Sysnative. Sorry for the delay. If you are still in need of assistance, please do the following. SFC Scan & Log 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 15, 2015 #4 Thanks. Please do the following. Remove Update Manually 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter wusa /uninstall /KB:3000850 3. Let me know if it says it was successful or if there are any errors.
P phillywells Member Joined Jul 9, 2015 Posts 7 Jul 15, 2015 #5 When i tried to uninstall that update, I got this
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 15, 2015 #6 Thanks. When you go to Windows Update does it show any updates to install?
P phillywells Member Joined Jul 9, 2015 Posts 7 Jul 15, 2015 #7 No problem, and yes it is showing updates as of now.
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 15, 2015 #8 Are you able to install them?
P phillywells Member Joined Jul 9, 2015 Posts 7 Jul 15, 2015 #9 Yep, they installed without a problem. Also had to restart afterwards.
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 15, 2015 #10 Cool. Let's do the following again. SFC Scan & Log 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 16, 2015 #12 Thanks. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Attachments SFCScript.txt 57 bytes · Views: 2
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jul 16, 2015 #14 Thank you. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - SFC Scan & Log 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix.txt 2. CBS.txt Attachments SFCFix.zip 4.6 KB · Views: 15
