DISM error array bounds are invalid
affannimattia
Apr 14, 2025
2
Hi everyone and thank you for sharing your knowledge.
I'm trying to resolve some strange issues on a Windows Server 2016 virtual machine.
When creating a folder, 4 new folders are being created without reason.
I ran these commands:
sfc /scannow that returnet everything was ok
and DISM /Online /Cleanup-Image /RestoreHealth which gave me "array bounds are invalid".
Here's my CBS logs if anyone can help :).
I thought KB4038782 was the problem, but it does not seem to be installed.
Thank you!
Hi @affannimattia,
Which folder are your creating and which ones are created too ?
FRST Registry Search
  1. Click the Start button and in the search box, type CMD
  2. When you see cmd.exe on the list, right-click on it and select Run as administrator.
  3. When command prompt opens, copy and paste the following command into it, press enter afterwards.
    REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
    Note: This loads your components hive which is what we want. Please keep the command prompt window open while you perform the remaining steps. You can minimize it if you wish but keep it open.
  4. Download the Farbar Recovery Scan Tool and save it to your Desktop:
  6. Copy and paste KB4038782 into the Search box and click the Search Registry button.
Hi Peter, thank you for helping me.
When I create a new folder with right click, 4 new Folders are created:
New Folder
New Folder(2)
New Folder(3)
New Folder(4)
If I create a new folder from cmd this does not happen. It seems to happen in specific folders, maybe due to permission errors or something. I'm investigating with procmon.
I attached the requested file.
Thank you!
  3. Press the Fix button.
Restart the machine.
Run the command sfc /scannow in an elevated commandprompt and report the result.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
