Hello,
the OS is Windows 11 build 26100.3323.
I checked my computer this week with sfc and dism and both found some errors and tried to fix them.
Sfc managed to fix the errors successfully and subsequent calls of sfc show that everything is operating correctly on my computer now. At least for that what sfc checks.
Unluckily I can't say the same about dism. :-(
When run with /scanhealth it says that there are errors that can be repaired, but when I try to repair them with /restorehealth, the program hangs at 62.3% and that's it. 0% cpu load on the process, 0% I/O, no error message on the command prompt.
I attached my cbs.log and dism.log.
Kind regards,
Chris
Kind regards,
Chris
