[SOLVED] DISM RestoreHealth fails (missing catalogs)
wvw
Well-known member
I have a Win 2016 DC I am trying to shrink WinSxS on. StartComponentCleanup fails; RestoreHealth fails. The RH failures I get are the two seemingly common ones: "the source files could not be found" and "array index out of bounds". I have been able to fix some of the errors in CBS.log by downloading old KBs, expanding the .cabs and pointing DISM there, but the remainder of my errors are for KBs that have been rolled into SSUs (which RestoreHealth doesn't seem to recognize the same way) or other. I have tried running SFCFix and it didn't detect any corruption, despite DISM erroring out. Would really appreciate any help as I am trying to not have to reinstall Windows and upend this site.
Thanks.
-Attached some logs, though I don't think the SFCFix really accompished anything and the log is kinda useless
My apologies, I didn't see the posting instructions before. I have attached the correct files to this reply.
Step 1. Download
  • Thanks
Reactions: wvw
The RestoreHealth operation completed successfully! Thank you very much.
I tried running StartComponentCleanup afterward which failed unfortunately. Is that something you can help with? The WinSxS folder on this server is almost 80GB at this point.
Step 1. Please run the following command first and copy past the result in your next post:
DISM /online /cleanup-image /AnalyzeComponentStore
Step 2. Download the
  • Press the Fix button.
  • Thanks
Reactions: wvw
Please open an elevated prompt, run the following command and post the result:
Dism /Online /Remove-Package /PackageName:Package_for_KB3202790~31bf3856ad364e35~amd64~~10.0.1.0
  • Thanks
Reactions: wvw
Version: 10.0.14393.4169
Image Version: 10.0.14393.4169
Processing 1 of 1 - Removing package Package_for_KB3202790~31bf3856ad364e35~amd64~~10.0.1.0
Please run the following command again and post the result:
DISM /online /cleanup-image /StartComponentCleanup
C:\Users\Administrator>DISM /online /cleanup-image /StartComponentCleanup
Error: 14098
The component store has been corrupted.
Step 1. Download
ComponentsScanner and save it to your desktop.
  • Right-click ComponentsScanner.exe and select "Run as administrator", click Yes on the UAC (User Account Control) prompt which appears.
  • Follow the on-screen instructions.
  • Once complete, a report will be saved to your desktop called ComponentsScanner.txt.
  • Post the logfile ComponentsScanner.txt as attachment into your next reply.
Step 2. Upload your COMPONENTS hive.
Follow these instructions to remove an update.
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:4025334
  • Let me know if it says it was successful or you get the message: The update KB4025334 is not installed on this computer.
Please run also the following command in an elevated prompt and attach Packages.txt to your next post.
DISM /online /get-packages /format:table > "%USERPROFILE%\desktop\Packages.txt"
Download the
  • Open the startmenu and type the command cmd.
  • After you find the Command Prompt, right click on it and select Run as Administrator.
  • Copy and paste the following into the Command Prompt and press enter.
Right-click on the file FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Registry button.
KB4025334;KB3200970
  • When the scan is complete, a message will display that SearchReg.txt is saved in the same folder FRST was started from.
  • Post the logfile SearchReg.txt as attachment in your next reply.
Please do the following:
Step 1.
  • Thanks
Reactions: wvw
