CONCLUSION
LatencyMon has been analyzing your system for 0:54:21 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: VALERIO-PC
Hardware: ASRock, H97 Pro4
CPU: GenuineIntel Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
Logical processors: 4
Processor groups: 1
RAM: 8133 MB total
CPU SPEED
Reported CPU speed: 3193 MHz
Highest measured interrupt to process latency (µs): 467,960427
Average measured interrupt to process latency (µs): 1,77990
Highest measured interrupt to DPC latency (µs): 452,244141
Average measured interrupt to DPC latency (µs): 0,566773
REPORTED ISRs
Highest ISR routine execution time (µs): 101,314751
Highest reported total ISR routine time (%): 0,029305
Total time spent in ISRs (%) 0,049485
ISR count (execution time <250 µs): 808147
REPORTED DPCs
Highest DPC routine execution time (µs): 1264,515503
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 364.72 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0,043351
Driver with highest DPC total execution time: cmudaxp.sys - C-Media Audio WDM Driver, C-Media Inc
Total time spent in DPCs (%) 0,158373
DPC count (execution time <250 µs): 11613164
DPC count (execution time 500-999 µs): 6
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 54935
Hard pagefault count of hardest hit process: 40375
Highest hard pagefault resolution time (µs): 2329917,304729
Total time spent in hard pagefaults (%): 1,398135
Number of processes hit: 30
PER CPU DATA
CPU 0 Interrupt cycle time (s): 46,734830
CPU 0 ISR highest execution time (µs): 101,314751
CPU 0 ISR total execution time (s): 6,453569
CPU 0 ISR count: 807645
CPU 0 DPC highest execution time (µs): 1264,515503
CPU 0 DPC total execution time (s): 11,760141
CPU 0 DPC count: 9384062
CPU 1 Interrupt cycle time (s): 26,317725
CPU 1 ISR highest execution time (µs): 45,083620
CPU 1 ISR total execution time (s): 0,001554
CPU 1 ISR count: 502
CPU 1 DPC highest execution time (µs): 736,628876
CPU 1 DPC total execution time (s): 5,060832
CPU 1 DPC count: 1904494
CPU 2 Interrupt cycle time (s): 24,735922
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 231,897902
CPU 2 DPC total execution time (s): 1,779669
CPU 2 DPC count: 161899
CPU 3 Interrupt cycle time (s): 32,301954
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 256,530222
CPU 3 DPC total execution time (s): 2,058671
CPU 3 DPC count: 162716
