Hi again Calcifer
We've had a lot of issues similar to yours in the forums lately... so, in addition to the three steps just mentioned (turn off Photos, Windows Update settings change, and Notification settings change) .... I have a few more steps to recommend (since there doesn't seem to be any guarantee for a single fix)...
Storport.sys/iastor.sys & Intel Rapid Storage Technology
I've actually recommended this for a few other troubled systems in the past, but it's been a while, so I'm going to link to a how-to (rather than trying to remember each exact step). Basically, you move from using the Intel-specific Rapid Storage Technology drivers, to using generic drivers.
Uninstalling the Intel(R) Rapid Storage Technology driver - Microsoft Community
Generic USB 3.0 driver rather than Asus/Asrock provided USB 3.0 driver
If the current USB 3.0 driver is the Asus/Asrock version (usually downloaded from their website, or installed from a "driver CD" that comes with the motherboard), try using a generic Intel USB 3.0 driver. You can try uninstalling the current driver using Device Manager, and then visiting Windows update (probably before you restart [so that you don't end up reinstalling the same Asus-version driver]) and let Windows Update provide whatever USB 3.0 driver it has in its library.
High Interrupt count for the nvlddmkm.sys Nvidia driver
I've been looking into several threads with this driver experiencing high interrupt counts - and your computer is one of those showing this effect. I think, but I'm not sure yet, that the driver has to do with power management for the Nvidia card. There have been several strategies used to varying success mentioned in tech forums, here are a few of the ideas:
1) If you haven't already, set your Energy Plan to "Maximum Performance" in Control Panel's "Power Options" app.
2) If that step doesn't help, you can try using an old app to lower the Nvidia power management settings, called Nvidia "PowerMizer". This used to help a few users who had Windows 7 - some Windows 10 users report that it helps in 10 also ... [though some report that sometimes updates arrive, and then they have to re-set the power settings again using PowerMizer]. The trick is to lower the settings, as mentioned in the thread (scroll down to the reply by Douglas Wilcox):
Screen going black but still running - General Hardware - Laptop - Dell Community
3) If neither of those steps help, you can try an alternate/opposite attempt --- use a few Registry tweaks to disable the power management of nvlddmkm.sys ... this will only work if the Windows 10 Nvidia Registry settings are in the same places as the Windows 7 settings...
SOLVED! Dropouts, Cracks, Pops on Windows 7 and NVIDIA GFX CARD! | NI User Forum
A few systems are trying these steps --- let us know if you have any success...
