SFC will not run, Windows Update is broken. I'm sure you know both of these from the post title.
I cannot Just simply Restore/Reformat.
System had a HDD fail, I was able to clone the HDD and save the information but obviously it has done some damage. Can this be fixed?
https://onedrive.live.com/redir?resid=C6BD05FD866CB2DD!917 <-- CBS.zip
Just let me know what I can do to help you help me.
Thanks.
PS I couldn't get attachments to work so I uploaded to my OneDrive.
SFCFix version 2.4.0.1 by niemiro.
Start time: 2014-08-23 15:47:09.951
WARNING: Components hive failed size test and may be corrupt.
CBS & SFC total detected corruption count: -13861
SFCFix version 2.4.0.1 by niemiro has completed.
Finish time: 2014-08-23 15:48:52.287
Thanks.
