I've just noticed that you've changed the arguments you've passed in from your last example. For your third parameter, I would advise using the predefined formatting strings, see if that makes a difference.TraceEvents(TRACE_LEVEL_INFORMATION, TRACE_DRIVER, "File Name: %wZ", &Data->Iopb->TargetFileObject->FileName);
yes, i read it but i can't find sample for my situationI've just noticed that you've changed the arguments you've passed in from your last example. For your third parameter, I would advise using the predefined formatting strings, see if that makes a difference.
