I have not been online recently, as my laptop broke. Upon waking it from sleep, all I get is a blue colored screen (not sure if a BSOD or not) saying:
Then the screen with that information on it just sits there as-is.
The OS is an OEM version of Windows 8.1 x64 and has a Recovery partition. I can get a full retail version version of Windows 8.1 x64, but it will not allow me to repair this OEM version.
In my opinion, it is likely that the hard drive is bad (some bad sectors), although I did boot into Recovery and checked many directories and files via command prompt (CMD) and had no problems maneuvering around. There are files on the two hard drive partitions that I would like to copy out (probably using CMD/ batch file; xcopy command) to a USB drive.
I do have a back-up 7 TB USB drive that other laptops I plug it in to give off an error message "...a hard drive that was just plugged in is malfunctioning...". I just cannot seem to win here at all!
There are other reasons for this error that I have found - related to the boot configuration and several sites suggest CMD commands too fix the system.
- Google Search - 0xc34 - 0xc0000034 - Google Search
- 0xc0000034 – Fix for Windows Vista, 7, 8, 10 (neosmart.net)
- How to Fix Error Code: 0xc0000034 - MajorGeeks
- 4 Solutions to Fix Windows 10 Error Code 0xc0000034 (wondershare.com)
Regardless, ideally, I would like to copy files off of the two HDD partitions onto a USB drive (about 700 GB total); install a new 500 GB SSD; Install Full Retail version of Windows 10 x64 Professional. I have thoroughly enjoyed Windows 8.1 x64, but it is time to move up to Windows 10.
Thanks. . .
John
@Wrench97 - Windows 10 is finally on the horizon, Bruce!
Error = 0xc0000034
File: c:\BCD
Thanks. . .
John
