Error 14081: Server 2019 Evaluation to Standard Conversion
ShadowByteX99
I have a physical machine running Server 2019 eval and am trying to convert it to the full version. I have tried running the following command:
dism /online /set-edition:ServerStandard /productkey:N69G4-B89J2-4G8F4-WWYCC-J464C /accepteula
But I get this error:
Error: 14081
An error occurred while operating system components were being updated. The upgrade cannot proceed.
Tried all the troubleshooting steps in the posting instructions, but am still getting the same error.
Any help would be much appreciated, thanks!
Hi @ShadowByteX99,
Follow these instructions to remove an update.
  • Open the Start menu of Windows and type the command CMD
  • When command prompt opens, copy and paste the following command into it, then press enter.
wusa /uninstall /KB:5013941
  • Let me know if it says it was successful or you get the message: The update KB5013941 is not installed on this computer.
Download the
  • Open the startmenu and type the command cmd.
  • After you find the Command Prompt, right click on it and select Run as Administrator.
  • Copy and paste the following into the Command Prompt and press enter.
Right-click on the file FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Registry button.
KB5013941
  • When the scan is complete, a message will display that SearchReg.txt is saved in the same folder FRST was started from.
  • Post the logfile SearchReg.txt as attachment in your next reply.
Start the
  • Right-click on FRST64.exe and select "Run as administrator".
  • Press the Fix button.
Afterwards try to convert the server edition and post the result. If it fails attach a new copy of the CBS logs.
