Error 80070490 when installing updates
vkd
Hello, I have a problem when updating the computer. The computer gives error 80070490 on each update.
I have run sfc /scannow and the system update readiness tool and neither have fixed the issue.
I ran SFCFix which produced the log file as shown below.
What can we do to solve the issue?
Start time: 2015-11-24 19:33:26.851
CORRUPT: C:\Windows\winsxs\msil_system.runtime.seri..ion.formatters.soap_b03f5f7f11d50a3a_6.1.7601.18523_none_1c70653de072abde\System.Runtime.Serialization.Formatters.Soap.dll
CORRUPT: C:\Windows\winsxs\msil_system.serviceprocess_b03f5f7f11d50a3a_6.1.7601.18523_none_295b4fe639372c78\System.ServiceProcess.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-hlink_31bf3856ad364e35_6.1.7600.16385_none_5798812ac56f3f37\hlink.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-safedocs-main_31bf3856ad364e35_6.1.7601.17514_none_27112637c50aacd7\sdrsvc.dll
CORRUPT: C:\Windows\winsxs\x86_mdmoptn.inf_31bf3856ad364e35_6.1.7600.16385_none_990adbf7b72d0c5f\mdmoptn.inf
CORRUPT: C:\Windows\winsxs\x86_mdmpn1.inf_31bf3856ad364e35_6.1.7600.16385_none_602c3247c694b3d5\mdmpn1.inf
CORRUPT: C:\Windows\winsxs\x86_mdmpp.inf_31bf3856ad364e35_6.1.7600.16385_none_4db364ac33248920\mdmpp.inf
CBS & SFC total detected corruption count: 22
SURT total detected corruption count: 21
Finish time: 2015-11-24 19:40:26.296
Hi and welcome to Sysnative. Please do the following so I can get a fresh full log which will help me diagnose/fix your issue.
SFC Scan
  1. Click on the Start
Step#1 - SFCFix Script
Step#2 - SFC Scan
Items for your next post
1. SFCFix.txt
2. CBS.txt
The the attchment you find the results.
After running the fix we also ran the sfcfix.exe again to see if all detected errors were solved, but then we found still three items
Thank you. Please only run the steps provided. Re-running SFCFix is not giving you an accurate result of what needs resolved. Please do the following.
Step#2 - SFC Scan
Step#3 - System Update Readiness Tool (SUR)
1. SFCFix.txt
2. CBS.txt
3. CheckSUR.log
Step#2 - System Update Readiness Tool (SUR)
1. SFCFix.txt
2. CheckSUR.log
