M mary New member Joined Jul 21, 2024 Posts 1 Jul 21, 2024 #1 Hi All ; I am looking for help with a Windows Update problem - error 0x800700c1 The PC runs Windows 10 Pro version 22H2, OS Build 19045.4529 I also tried to install Arcgis and i cant plz help me When I try to run Windows update, it doesn't work and gives error 0x800700c1 I have tried the following per forum instructions: Step 1: SFC Scan This does not run and says the following: Step 2: DISM This also does not run plllzzz help me ://// Attachments CBS.zip 4.9 MB · Views: 3 dism.log 5.4 MB · Views: 0
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,397 Location The Netherlands Jul 24, 2024 #2 Hi and welcome to Sysnative, Step 1. Download SFCFix and save it to your desktop. Warning: This fix was written specifically for this system. Do not run this fix on another system. Save any work you have open, and close all programs. Download the attachment SFCFix.zip and save it to your desktop. Drag the SFCFix.zip file over the SFCFix.exe executable and release it. SFCFix will launch, let it complete. Once done, a file will appear on your desktop, called SFCFix.txt. Post the logfile (SFCFix.txt) as attachment in your next reply. Step 2. Run the following DISM command and post the result. If it fails attach a new copy of the CBS log. Code: DISM /online /cleanup-image /RestoreHealth Attachments SFCFix.zip 40.9 KB · Views: 3
