J jeezy63 New member Joined Jul 23, 2024 Posts 4 Jul 23, 2024 #1 Hello, I have been trying to update different drivers along with windows 11 23H2 for months and I continue to get the error code 0x800703f1. I have tried all of the remedies suggested via youtube along with other various google searches with no luck. Please help.
J jeezy63 New member Joined Jul 23, 2024 Posts 4 Jul 23, 2024 #2 Running windows 10 Attachments CBS.zip 2.3 MB · Views: 3 ComponentsScanner.txt 711 bytes · Views: 3
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,168 Location The Netherlands Jul 26, 2024 #3 Hi and welcome to Sysnative, Upload your DRIVERS Hive Navigate to C:\Windows\System32\config and locate the DRIVERS file. Please copy this file to your desktop. Note: If you receive an error that this file is in-use, simply reboot your computer and try again. Right-click on this file on your desktop and select Send To > Compressed (zipped) folder. This will create a file named DRIVERS.ZIP on your desktop. If the file is too large to upload here, upload the file to www.wetransfer.com and post the link in your next reply.
J jeezy63 New member Joined Jul 23, 2024 Posts 4 Jul 26, 2024 #4 Thank you for responding. Attachments DRIVERS.zip 1.4 MB · Views: 2
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,168 Location The Netherlands Jul 27, 2024 #5 Hi, Replace Drivers Hive Manually Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download DRIVERS.ZIP and save to your desktop. Right-click on it and select Extract all.... Make sure the "Show extracted files when complete" is checked and click Extract. Now we have the DRIVERS file that we will be using to replace your current one. Navigate to C:\Windows\System32\config Right-click on the current DRIVERS file and select rename. Rename it to DRIVERS.bad. Note: If you get an error that the file is in use, reboot your computer and then try again. Take the file from the Drivers folder on your desktop and paste it into C:\Windows\System32\config Afterwards reboot the system and attempt to update. If it fails attach a new copy of the CBS logs. Attachments DRIVERS.zip 1.4 MB · Views: 2
J jeezy63 New member Joined Jul 23, 2024 Posts 4 Jul 28, 2024 #6 it worked. everything updated. thank you.
Maxstar Windows Update Moderator, Security Analyst Staff member Joined Aug 16, 2015 Posts 13,168 Location The Netherlands Jul 28, 2024 #7 Hi, You're welcome. Glad to hear everything is up-to-dat now... I will mark this thread as solved.
