[SOLVED] Error Code 0x80073712
Results:
STEP1:
Start time: 2019-08-04 11:32:27.104
Microsoft Windows Server 2012 - amd64
Using .zip script file at D:\Profilo\Administrator\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.22802_none_5ba1a50ae5ca97eb\gdiplus.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.9200.22802_none_6c5036264cc4be44\gdiplus.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus.systemcopy_31bf3856ad364e35_6.2.9200.22802_none_4082338898b06f67\gdiplus.dll
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.22802_none_5ba1a50ae5ca97eb\gdiplus.dll to C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.22802_none_5ba1a50ae5ca97eb\gdiplus.dll.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.9200.22802_none_6c5036264cc4be44\gdiplus.dll to C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.9200.22802_none_6c5036264cc4be44\gdiplus.dll.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_microsoft.windows.gdiplus.systemcopy_31bf3856ad364e35_6.2.9200.22802_none_4082338898b06f67\gdiplus.dll to C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus.systemcopy_31bf3856ad364e35_6.2.9200.22802_none_4082338898b06f67\gdiplus.dll.
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.22802_none_5ba1a50ae5ca97eb\gdiplus.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.9200.22802_none_5ba1a50ae5ca97eb\gdiplus.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.9200.22802_none_6c5036264cc4be44\gdiplus.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.0.9200.22802_none_6c5036264cc4be44\gdiplus.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus.systemcopy_31bf3856ad364e35_6.2.9200.22802_none_4082338898b06f67\gdiplus.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus.systemcopy_31bf3856ad364e35_6.2.9200.22802_none_4082338898b06f67\gdiplus.dll
FileScan::
[0: 1] C:\Windows\WinSxS\x86_microsoft-windows-store-runtime_31bf3856ad364e35_6.2.9200.16811_none_edd84a4c108df7ee\WSShared.dll
Expected: rlQshEmdw4Qy1oO4CguLaWXU01GfL/p9mVVOyOc+wYM=
Expected: 6.2.9200.16811
Successfully traced component x86_microsoft-windows-store-runtime_31bf3856ad364e35_6.2.9200.16811_none_edd84a4c108df7ee.
Package_121_for_KB2928678~31bf3856ad364e35~amd64~~6.2.1.1.2928678-278_neutral_LDR3
Currently storing 22 datablocks.
Finish time: 2019-08-04 11:32:47.366
Script hash: nAWFn5V3dLL6gvpO08XRjGN5Ex5Wk1SLmr4s1a9pgyM=
STEP2:
C:\Windows\system32>Dism /Online /Cleanup-Image /RestoreHealth
Version: 6.2.9200.16384
Image Version: 6.2.9200.16384
Error: 14005
The manifest file contains one or more syntax errors.
CBS.zip
Let's see if ProcMon can help us track down a few more issues:
Capture Process Monitor Trace
2. Try updating the system just like you have in the past.
3. Stop Process Monitor as soon as the it fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
I would like to offer my apologies that there is a delay in the next repair to your system. There were some unexpected complexities found in your logs, and we will need some additional time to develop a plan of action. Thank you for your patience.
Step 1
Memory Concerns
Have you recently replaced the memory (RAM) in your system? There were bit shifts detected in a couple registry keys, which can be indicative of faulty RAM. If you have not recently replaced your RAM, I highly advise that you proceed with memory diagnostics before proceeding to Steps 2-3. If you do not already have memory diagnostic tools for testing your server hardware, we recommend using Test RAM with PassMark MemTest86
Step 2
FRST Fix
  6. Try to install updates again, and if any fail, attach the CBS.log.
Step 3
DISM /RestoreHealth Scan
    Please Note:: if the file is too big (over 7MB) to upload to your next post, please upload via a service such as Dropbox or OneDrive or SendSpace and just provide the link.
Thank you for supporting writhziden, don't worry if you need more time.
The important thing is that we can get to the end of this problem.
Results:
STEP1
(I not have recently replaced RAM)
The Windows Memory Diagnostic tested the computer's memory and detected no errors
STEP2
See log attached
STEP3
Error: 14005
CBS.zip
Please do the following:
  1. Point to: Bottom right corner
  2. Click on: Search (The magnifying glass icon)
  3. Under: Search (Apps)
  4. Type: Regedit
  5. Select and open Registry Editor
  6. Collapse any open hives (directory icons)
  7. Take a screenshot with Print Screen and crop it with Paint or use the snipping tool to capture an image of your Registry Editor
    It should look similar to below:
  8. Upload the image in your next post
Your main registry hives look good. Thanks for verifying. Can you please provide the most recent version of your COMPONENTS hive?
Retrieve Components Hive
If you are unable to follow those instructions due to the hive being in use by the server, follow the below procedure instead:
It looks like you have an extra, bad key floating around that I missed removing earlier. Follow the below steps to remove it and allow us to verify it was removed.
Step 1
FRST Fix
Step 2
Step 1
Fix result of Farbar Recovery Scan Tool (x64) Version: 10-08-2019
Ran by Administrator (14-08-2019 09:50:50) Run:6
Running from D:\Profilo\Administrator\Desktop
Loaded Profiles: UpdatusUser & Administrator & MSSQL$MICROSOFT##WID & SQLTELEMETRY & SQLSERVERAGENT & MSSQLSERVER (Available Profiles: UpdatusUser & Administrator & MSSQL$MICROSOFT##WID & SQLTELEMETRY & SQLSERVERAGENT & MSSQLSERVER & .NET v4.5 & .NET v4.5 Classic)
Boot Mode: Normal
fixlist content:
CMD: REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
CloseProcesses:
CreateRestorePoint:
DeleteKey: HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea0defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932
ExportKey: HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea0defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932
ExportKey: HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea1defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932
========= REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS =========
Error: (0) Failed to create a restore point.
HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea0defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932 => removed successfully
================== ExportKey: ===================
"HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea0defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932" => not found
=== End of ExportKey ===
[HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5d18801b471eebde819ea1defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_none_23e4bcb26106e932]
"S256H"="e1f43994360521bdf67754d61526a76b46ef9a30b948d9664383b16ad3084f10"
"identity"="35643138383031623437316565626465383139656131646566633365316533622c2043756c747572653d6e65757472616c2c2056657273696f6e3d362e322e393230302e32303532312c205075626c69634b6579546f6b656e3d33316266333835366164 (the data entry has 112 more characters)."
"CF"="12"
"c!5d18801b471..1defc3e1e3b_31bf3856ad364e35_6.2.9200.20521_23e4bcb26106e932"=""
The system needed a reboot.
==== End of Fixlog 09:51:17 ====
Step 2
CBS.zip
Let's see if ProcMon can help us track down your DISM issues:
  1. Once again, we will need you to run Process Monitor.
  2. This time, try to start Process Monitor as close as you can to when the failure occurs when running DISM /Online /Cleanup-Image /RestoreHealth (within 1-5 minutes of failure).
  3. Stop Process Monitor as soon as DISM fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
C:\Windows\system32>DISM /Online /Cleanup-Image /RestoreHealth
The restore operation failed. Either the repair source was not found or the component store cannot be repaired.
Error: 0x800f081f
DISM failed. No operation was performed.
This is log Logfile.zip
Thank you. Can we also please see your CBS folder?
  1. Press the Windows key, type This PC, and press Enter.
  2. Double-click on the C: drive, under the Hard Disk Drives category, and then scroll down to, and double click on the Windows folder.
  3. Find and double click on the Logs folder.
  4. Right-click on the CBS folder, and select Copy.
  5. Go back to your Desktop, right-click on it, and select Paste. You should now see a copy of the CBS folder appear on your Desktop called CBS.
  6. Right-click on this new folder, and navigate through Send to, and select Compressed (zipped) folder.
  7. A new file, also called CBS (CBS.zip), but this time with a different icon, will be created on your desktop.
  8. Provide a link to the CBS.zip archive you upload. Examples of services to upload to are Dropbox or OneDrive or SendSpace
I'm afraid that set of logs came too long after DISM ran. We will need to get the logs immediately after the DISM repair attempt. Please follow the steps to do so below:
Step 1
  3. Report back to us with the full error message (take a screenshot if you can).
Step 2
Provide the Full CBS Directory
Hello!
As writhziden is currently busy, I am going to shortly step in and provide the next steps for you to follow:
2. Try updating the system just like you have in the past, but this time, I want you to select only a single update.
If you receive something else instead of an error code, please stop and let me know.
Your next reply should contain:
1. A description of what happened
2. KB number of the update you have attempted to install
3. A link to the Process Monitor Logfile and the CBS.log.
Thank you for your patience whilst we are troubleshooting this.
