I have a problem in Windows 7 x64, when I run the program I get the error clr20r3 error. This happened after trying to update the program, the new version also didn't work anymore (new wersion is dedicated to windows 10/11). Then I reinstalled the earlier working version and it stopped working. I tried to use procdump, but the target program immediately turns off when I connect procdump to it.
I tried to reinstall .NET Framework 4.5.1, 4.8 EN/PLK, nothing helped.
i tried using Microsoft .NET Framework Repair Tool - still error during lunching program.
I used ccleaner and avast was installed, but I removed it normally without the avast_av_cleaner tool - maybe it's a mistake...
most Dism commands end with error 87.
I tried to update Windows using a DVD image on a USB PenDrive, but it rolls back the updates at the last step. When using SfcFix I see a lot of errors... please help me how to repair the system
Laptop Toshiba Satelite Pro 500
CPU Intel Core i5 M580 2.6ghZ
ram: 4 GB
HDD: 500GB
everything I tried to do, the output is in the attachment:
Package "Package_for_KB5001027~31bf3856ad364e35~amd64~~6.1.1.3" requires Servicing Stack v6.1.7601.24554 but current Servicing Stack is v6.1.7601.24544. [HRESULT = 0x800f0823 - CBS_E_NEW_SERVICING_STACK_REQUIRED]
2024-10-29 13:09:08, Info CBS Failed to initialize internal package [HRESULT = 0x800f0823 - CBS_E_NEW_SERVICING_STACK_REQUIRED]
2024-10-29 13:09:08, Error CBS Failed to create internal package [HRESULT = 0x800f0823 - CBS_E_NEW_SERVICING_STACK_REQUIRED]
ram: 4 GB
HDD: 500GB
