I'm using Windows 10 on an HP ProBook laptop. I am able to connect a second monitor to my HP ProBook using an old-fashioned 15-pin video cable. But when I connect using an HDMI cable I get the message check signal cable. There are two separate HDMI inputs on the monitor, but it doesn't make any difference which one I use. The cable is securely connected to both the laptop and the monitor. I'm pretty sure my cable is good because I've used it with other devices. Before I go out and purchase another HDMI cable, is there a setting I should look at?
