Error reporting options disabled by group policy
calcu007
Well-known member
The options are greyout. Maybe a software disable it and I dont know how enable it back. I am using Win 8.1 8D7Ca.png
Hello calcu,
Are you part of a domain?
If not please post the following log.
Event Log Viewer
  1. Please download VEW.exe from Here and save it to your desktop.
  2. Go to your desktop and right click on VEW.exe and choose Run as Administrator
  3. Once open set the following settings
    • 'Select log to query'
      1. Tick Application
      2. Tick System
    • 'Select Type to list'
      1. Tick Critical
      2. Tick Error
      3. Tick Information
      4. Tick Warning
    • 'Number or date events'
      1. Tick Number of Events and set it to 20
  4. Click on Run
  5. Once completed a notepad file will open. Please copy and paste the contents of VEW.txt back into this thread.
I already found a fix with a registry change, but here is the info requested, tell me if you found anyelse wrong
Vino's Event Viewer v01c run on Windows 7 in English
Report run at 19/12/2014 10:35:13 AM
Note: All dates below are in the format dd/mm/yyyy
'Application' Log - Critical Type
'Application' Log - Error Type
Log: 'Application' Date/Time: 19/12/2014 12:14:13 PM
Type: Error Category: 0
Event: 255 Source: iumsvc
The event description cannot be found.
Log: 'Application' Date/Time: 19/12/2014 12:14:07 PM
Log: 'Application' Date/Time: 19/12/2014 12:14:05 PM
Log: 'Application' Date/Time: 19/12/2014 12:14:03 PM
Log: 'Application' Date/Time: 19/12/2014 12:14:02 PM
Log: 'Application' Date/Time: 19/12/2014 12:13:08 PM
Type: Error Category: 101
Event: 1002 Source: Application Hang
The program backgroundTaskHost.exe version 6.3.9600.17415 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel. Process ID: 12c8 Start Time: 01d01b846cced554 Termination Time: 4294967295 Application Path: C:\WINDOWS\system32\backgroundTaskHost.exe Report Id: 628bcdc2-8778-11e4-82e0-ac220baf2615 Faulting package full name: Facebook.Facebook_1.4.0.9_x64__8xx8rvfyw5nnt Faulting package-relative application ID: App
Log: 'Application' Date/Time: 19/12/2014 12:07:38 PM
Event: 1008 Source: Microsoft-Windows-Perflib
The Open Procedure for service "BITS" in DLL "C:\Windows\System32\bitsperf.dll" failed. Performance data for this service will not be available. The first four bytes (DWORD) of the Data section contains the error code.
Log: 'Application' Date/Time: 19/12/2014 5:29:31 AM
Type: Error Category: 100
Event: 1000 Source: Application Error
Faulting application name: DVDFab.exe, version: 9.1.7.9, time stamp: 0x5488118f Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000 Exception code: 0xc0000005 Fault offset: 0x2e5b1b78 Faulting process id: 0x163c Faulting application start time: 0x01d01b4cc2bf7c01 Faulting application path: C:\Program Files (x86)\DVDFab 9\DVDFab.exe Faulting module path: unknown Report Id: 01a92a75-8740-11e4-82df-ac220baf2615 Faulting package full name: Faulting package-relative application ID:
Log: 'Application' Date/Time: 19/12/2014 3:37:00 AM
Log: 'Application' Date/Time: 19/12/2014 3:36:59 AM
Log: 'Application' Date/Time: 19/12/2014 3:36:57 AM
Log: 'Application' Date/Time: 19/12/2014 3:36:55 AM
Log: 'Application' Date/Time: 19/12/2014 3:27:58 AM
The program LiveComm.exe version 17.5.9600.20689 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel. Process ID: 12b4 Start Time: 01d01b3b0ff6d4ae Termination Time: 4294967295 Application Path: C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.5.9600.20689_x64__8wekyb3d8bbwe\LiveComm.exe Report Id: 060033f0-872f-11e4-82df-ac220baf2615 Faulting package full name: microsoft.windowscommunicationsapps_17.5.9600.20689_x64__8wekyb3d8bbwe Faulting package-relative application ID: ppleae38af2e007f4358a809ac99a64a67c1
Log: 'Application' Date/Time: 19/12/2014 3:27:56 AM
The program LiveComm.exe version 17.5.9600.20689 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel. Process ID: 12b4 Start Time: 01d01b3b0ff6d4ae Termination Time: 4294967295 Application Path: C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_17.5.9600.20689_x64__8wekyb3d8bbwe\LiveComm.exe Report Id: 04475e1a-872f-11e4-82df-ac220baf2615 Faulting package full name: microsoft.windowscommunicationsapps_17.5.9600.20689_x64__8wekyb3d8bbwe Faulting package-relative application ID: ppleae38af2e007f4358a809ac99a64a67c1
The program backgroundTaskHost.exe version 6.3.9600.17415 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel. Process ID: 1218 Start Time: 01d01b3b0fce4cbc Termination Time: 4294967295 Application Path: C:\WINDOWS\system32\backgroundTaskHost.exe Report Id: 0445d737-872f-11e4-82df-ac220baf2615 Faulting package full name: Facebook.Facebook_1.4.0.9_x64__8xx8rvfyw5nnt Faulting package-relative application ID: App
Log: 'Application' Date/Time: 19/12/2014 2:54:06 AM
Log: 'Application' Date/Time: 19/12/2014 2:54:05 AM
'Application' Log - Information Type
Log: 'Application' Date/Time: 19/12/2014 1:33:54 PM
Type: Information Category: 0
Event: 0 Source: PDEngine
SMARTPlacement operation has been paused for drive C:\.
Log: 'Application' Date/Time: 19/12/2014 1:33:53 PM
Event: 66 Source: PDAgent
StealthPatrol schedule suspended on drive C:\ : System activity (kernel mode CPU) .
Log: 'Application' Date/Time: 19/12/2014 1:33:27 PM
SMARTPlacement operation has been resumed for drive C:\.
Event: 67 Source: PDAgent
StealthPatrol schedule resumed on drive C:\ .
Log: 'Application' Date/Time: 19/12/2014 1:28:21 PM
Log: 'Application' Date/Time: 19/12/2014 1:28:20 PM
Log: 'Application' Date/Time: 19/12/2014 1:21:21 PM
Log: 'Application' Date/Time: 19/12/2014 1:16:15 PM
Log: 'Application' Date/Time: 19/12/2014 1:16:14 PM
StealthPatrol schedule suspended on drive C:\ : System activity (disk I/O) .
Log: 'Application' Date/Time: 19/12/2014 1:11:03 PM
Log: 'Application' Date/Time: 19/12/2014 1:05:57 PM
Log: 'Application' Date/Time: 19/12/2014 1:05:56 PM
Log: 'Application' Date/Time: 19/12/2014 12:51:21 PM
Log: 'Application' Date/Time: 19/12/2014 12:46:15 PM
Log: 'Application' Date/Time: 19/12/2014 12:46:14 PM
Log: 'Application' Date/Time: 19/12/2014 12:39:33 PM
Log: 'Application' Date/Time: 19/12/2014 12:39:32 PM
'Application' Log - Warning Type
Log: 'Application' Date/Time: 19/12/2014 12:09:25 PM
Type: Warning Category: 0
Event: 1 Source: Microsoft-Windows-ApplicationExperienceInfrastructure
The application (Intel Bluetooth Wireless High Speed, from vendor Intel) has the following problem: To function properly, Intel Bluetooth Wireless High Speed must be reinstalled after you upgrade Windows.
Log: 'Application' Date/Time: 19/12/2014 12:09:12 PM
The application (Outpost, from vendor Agnitum Ltd.) has the following problem: To function properly, Outpost must be reinstalled after you upgrade Windows.
Log: 'Application' Date/Time: 19/12/2014 3:36:36 AM
Type: Warning Category: 1
Event: 532 Source: ESENT
LiveComm (3648) C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\: A request to read from the file "C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\DBStore\livecomm.edb" at offset 10289152 (0x00000000009d0000) for 8192 (0x00002000) bytes has not completed for 36 second(s). This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
LiveComm (3648) C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\: A request to read from the file "C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\DBStore\livecomm.edb" at offset 10256384 (0x00000000009c8000) for 8192 (0x00002000) bytes has not completed for 36 second(s). This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
Type: Warning Category: 7
Event: 507 Source: ESENT
LiveComm (3648) C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\: A request to read from the file "C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\DBStore\livecomm.edb" at offset 8962048 (0x000000000088c000) for 8192 (0x00002000) bytes succeeded, but took an abnormally long time (42 seconds) to be serviced by the OS. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
Log: 'Application' Date/Time: 19/12/2014 3:24:01 AM
Log: 'Application' Date/Time: 19/12/2014 3:24:00 AM
Log: 'Application' Date/Time: 19/12/2014 2:49:42 AM
Log: 'Application' Date/Time: 19/12/2014 2:49:37 AM
Log: 'Application' Date/Time: 19/12/2014 2:11:29 AM
LiveComm (1360) C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\: A request to read from the file "C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\DBStore\livecomm.edb" at offset 10698752 (0x0000000000a34000) for 8192 (0x00002000) bytes succeeded, but took an abnormally long time (24 seconds) to be serviced by the OS. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
Log: 'Application' Date/Time: 19/12/2014 2:08:22 AM
Log: 'Application' Date/Time: 19/12/2014 2:05:30 AM
Log: 'Application' Date/Time: 18/12/2014 11:42:05 AM
Log: 'Application' Date/Time: 18/12/2014 11:41:52 AM
Log: 'Application' Date/Time: 18/12/2014 5:46:56 AM
Log: 'Application' Date/Time: 18/12/2014 5:46:36 AM
Log: 'Application' Date/Time: 18/12/2014 5:12:31 AM
Type: Warning Category: 3
Event: 472 Source: ESENT
LiveComm (5844) C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\: The shadow header page of file C:\Users\Alexis\AppData\Local\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\LocalState\LiveComm\6b259be21302d5df\120712-0049\DBStore\livecomm.edb was damaged. The primary header page (8192 bytes) was used instead.
Log: 'Application' Date/Time: 18/12/2014 5:05:52 AM
Log: 'Application' Date/Time: 18/12/2014 5:05:45 AM
Log: 'Application' Date/Time: 18/12/2014 2:06:47 AM
'System' Log - Critical Type
Log: 'System' Date/Time: 05/12/2014 11:08:04 AM
Type: Critical Category: 63
Event: 41 Source: Microsoft-Windows-Kernel-Power
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
'System' Log - Error Type
Log: 'System' Date/Time: 19/12/2014 12:06:38 PM
Event: 7000 Source: Service Control Manager
The Apple Mobile Device service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
Event: 7009 Source: Service Control Manager
A timeout was reached (30000 milliseconds) while waiting for the Apple Mobile Device service to connect.
Log: 'System' Date/Time: 19/12/2014 3:28:09 AM
Event: 7034 Source: Service Control Manager
The Soluto PCGenome Core Service service terminated unexpectedly. It has done this 1 time(s).
Log: 'System' Date/Time: 19/12/2014 2:02:43 AM
The ASLDR Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
A timeout was reached (30000 milliseconds) while waiting for the ASLDR Service service to connect.
Log: 'System' Date/Time: 18/12/2014 5:44:06 AM
Log: 'System' Date/Time: 18/12/2014 5:07:57 AM
Event: 7022 Source: Service Control Manager
The Intel® Centrino® Wireless Bluetooth® + High Speed Service service hung on starting.
Log: 'System' Date/Time: 18/12/2014 3:43:07 AM
Event: 10016 Source: Microsoft-Windows-DistributedCOM
The machine-default permission settings do not grant Local Activation permission for the COM Server application with CLSID {C2F03A33-21F5-47FA-B4BB-156362A2F239} and APPID {316CDED5-E4AE-4B15-9113-7055D84DCC97} to the user CALCU\Alexis SID (S-1-5-21-1318044153-752161398-541790769-1002) from address LocalHost (Using LRPC) running in the application container Microsoft.BingNews_3.0.4.213_x64__8wekyb3d8bbwe SID (S-1-15-2-508114518-3340871649-811464485-526616082-4258465299-1774086546-1865468257). This security permission can be modified using the Component Services administrative tool.
Log: 'System' Date/Time: 17/12/2014 3:07:55 PM
Event: 10010 Source: Microsoft-Windows-DistributedCOM
The server {4AA0A5C4-1B9B-4F2E-99D7-99C6AEC83474} did not register with DCOM within the required timeout.
Log: 'System' Date/Time: 17/12/2014 3:07:25 PM
Log: 'System' Date/Time: 17/12/2014 7:15:45 AM
Event: 7023 Source: Service Control Manager
The Superfetch service terminated with the following error: The service has not been started.
Log: 'System' Date/Time: 17/12/2014 7:15:43 AM
The Software Protection service failed to start due to the following error: The service did not start due to a logon failure.
Event: 7038 Source: Service Control Manager
The sppsvc service was unable to log on as NT AUTHORITY\NetworkService with the currently configured password due to the following error: The security account manager (SAM) or local security authority (LSA) server was in the wrong state to perform the security operation. To ensure that the service is configured properly, use the Services snap-in in Microsoft Management Console (MMC).
Log: 'System' Date/Time: 17/12/2014 2:20:16 AM
Event: 20 Source: Microsoft-Windows-WindowsUpdateClient
Installation Failure: Windows failed to install the following update with error 0x80070005: Update for Windows 8.1 for x64-based Systems (KB2976978).
Log: 'System' Date/Time: 17/12/2014 2:12:25 AM
Log: 'System' Date/Time: 16/12/2014 2:45:07 AM
'System' Log - Information Type
Log: 'System' Date/Time: 19/12/2014 1:33:49 PM
Event: 7040 Source: Service Control Manager
The start type of the Background Intelligent Transfer Service service was changed from demand start to auto start.
Log: 'System' Date/Time: 19/12/2014 1:18:22 PM
The start type of the Background Intelligent Transfer Service service was changed from auto start to demand start.
Log: 'System' Date/Time: 19/12/2014 12:35:35 PM
Type: Information Category: 10
Event: 12 Source: Microsoft-Windows-UserModePowerService
Process C:\Windows\System32\WinSAT.exe (process ID:5500) reset policy scheme from {8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C} to {A1841308-3541-4FAB-BC81-F71556F20B4A}
Log: 'System' Date/Time: 19/12/2014 12:35:28 PM
Process C:\Windows\System32\WinSAT.exe (process ID:5500) reset policy scheme from {A1841308-3541-4FAB-BC81-F71556F20B4A} to {8C5E7FDA-E8BF-4A96-9A85-A6E23A8C635C}
Log: 'System' Date/Time: 19/12/2014 12:21:41 PM
Event: 19 Source: Microsoft-Windows-WindowsUpdateClient
Installation Successful: Windows successfully installed the following update: MAGIX.MusicMakerJam
Log: 'System' Date/Time: 19/12/2014 12:19:26 PM
Event: 43 Source: Microsoft-Windows-WindowsUpdateClient
Installation Started: Windows has started installing the following update: MAGIX.MusicMakerJam
Log: 'System' Date/Time: 19/12/2014 12:18:28 PM
Type: Information Category: 2
Event: 17 Source: Microsoft-Windows-WindowsUpdateClient
Installation Ready: The following updates are downloaded and ready for installation:
- MAGIX.MusicMakerJam
Log: 'System' Date/Time: 19/12/2014 12:15:48 PM
Log: 'System' Date/Time: 19/12/2014 12:10:46 PM
Event: 14206 Source: Microsoft-Windows-WMPNSS-Service
Media server 'CALCU: alexis_arenas@hotmail.com:' was successfully initialized and is sharing media with network media devices.
Log: 'System' Date/Time: 19/12/2014 12:10:43 PM
Event: 14204 Source: Microsoft-Windows-WMPNSS-Service
Service 'WMPNetworkSvc' started.
Log: 'System' Date/Time: 19/12/2014 12:07:43 PM
Event: 16 Source: Microsoft-Windows-Kernel-General
The access history in hive \??\C:\Users\Alexis\AppData\Local\Microsoft\Windows\UsrClass.dat was cleared updating 21502 keys and creating 2037 modified pages.
The access history in hive \??\C:\Users\Alexis\ntuser.dat was cleared updating 9785 keys and creating 753 modified pages.
Type: Information Category: 1101
Event: 7001 Source: Microsoft-Windows-Winlogon
User Logon Notification for Customer Experience Improvement Program
Log: 'System' Date/Time: 19/12/2014 12:07:23 PM
Event: 7026 Source: Service Control Manager
The following boot-start or system-start driver(s) did not load: dam
Log: 'System' Date/Time: 19/12/2014 12:06:48 PM
Process C:\Windows\System32\DptfPolicyConfigTDPService.exe (process ID:2316) reset policy scheme from {A1841308-3541-4FAB-BC81-F71556F20B4A} to {A1841308-3541-4FAB-BC81-F71556F20B4A}
Process C:\Windows\System32\DptfParticipantProcessorService.exe (process ID:2284) reset policy scheme from {A1841308-3541-4FAB-BC81-F71556F20B4A} to {A1841308-3541-4FAB-BC81-F71556F20B4A}
Log: 'System' Date/Time: 19/12/2014 12:06:47 PM
Event: 6 Source: Microsoft-Windows-FilterManager
File System Filter 'avckf' (6.1, ?2014?-?05?-?08T09:48:18.000000000Z) has successfully loaded and registered with Filter Manager.
Log: 'System' Date/Time: 19/12/2014 12:06:07 PM
Event: 10001 Source: Microsoft-Windows-WLAN-AutoConfig
WLAN Extensibility Module has successfully started. Module Path: C:\WINDOWS\System32\IWMSSvc.dll
Log: 'System' Date/Time: 19/12/2014 12:05:56 PM
Event: 4000 Source: Microsoft-Windows-WLAN-AutoConfig
WLAN AutoConfig service has successfully started.
Log: 'System' Date/Time: 19/12/2014 12:05:55 PM
Type: Information Category: 4
Event: 51046 Source: Microsoft-Windows-DHCPv6-Client
DHCPv6 client service is started
'System' Log - Warning Type
Log: 'System' Date/Time: 19/12/2014 12:06:45 PM
Event: 37 Source: Microsoft-Windows-Kernel-Processor-Power
The speed of processor 3 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
The speed of processor 2 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
The speed of processor 0 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
The speed of processor 1 in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report.
Log: 'System' Date/Time: 19/12/2014 12:05:50 PM
Event: 11 Source: Microsoft-Windows-Wininit
Custom dynamic link libraries are being loaded for every application. The system administrator should review the list of libraries to ensure they are related to trusted applications. Please visit Working with the AppInit_DLLs registry value for more information.
Log: 'System' Date/Time: 19/12/2014 12:05:39 PM
Event: 264 Source: Win32k
A multi-touch device reported inconsistent contact information.
Log: 'System' Date/Time: 19/12/2014 6:15:48 AM
Event: 134 Source: Microsoft-Windows-Time-Service
NtpClient was unable to set a manual peer to use as a time source because of DNS resolution error on 'time.windows.com,0x9'. NtpClient will try again in 15 minutes and double the reattempt interval thereafter. The error was: No such host is known. (0x80072AF9)
Event: 10002 Source: Microsoft-Windows-WLAN-AutoConfig
WLAN Extensibility Module has stopped. Module Path: C:\WINDOWS\System32\IWMSSvc.dll
Log: 'System' Date/Time: 19/12/2014 5:30:57 AM
Type: Warning Category: 1014
Event: 1014 Source: Microsoft-Windows-DNS-Client
Name resolution for the name tracker.openbittorrent.com timed out after none of the configured DNS servers responded.
Log: 'System' Date/Time: 19/12/2014 3:21:22 AM
Log: 'System' Date/Time: 19/12/2014 3:20:27 AM
Log: 'System' Date/Time: 19/12/2014 3:20:16 AM
Log: 'System' Date/Time: 19/12/2014 3:19:41 AM
Log: 'System' Date/Time: 19/12/2014 2:46:03 AM
These errors are interesting, but don't explain the issue you have reported. We will look at these after...
GPRESULT
  1. Right click on the
    button
  3. Inside the Command Prompt windows copy and paste the following command
    gpresult /Scope Computer /v >1&&notepad 1
  4. Once finished a notepad file will pop up. Please post the contents back here
License Information (Windows 8)
    button
  2. Click on Command prompt =>
    licensingdiag.exe -report "%userprofile%\Desktop\report.txt" -log "%userprofile%\Desktop\repfiles.cab"
  4. Once finished please go to your desktop -> You will see two files report.txt and repfiles.cab -> Please select both files and add them into a zip file
  5. Upload this zip file to your next reply
The second instuction dont work. I gor filename, directory or path syntax errir
Microsoft (R) Windows (R) Operating System Group Policy Result tool v2.0
c 2013 Microsoft Corporation. All rights reserved.
Created on 12/19/2014 at 11:02:41 PM
RSOP data for CALCU\Alexis on CALCU : Logging Mode
OS Configuration: Standalone Workstation
OS Version: 6.3.9600
Site Name: N/A
Roaming Profile: N/A
Local Profile: C:\Users\Alexis
Connected over a slow link?: No
COMPUTER SETTINGS
Last time Group Policy was applied: 12/19/2014 at 10:43:57 PM
Group Policy was applied from: N/A
Group Policy slow link threshold: 500 kbps
Domain Name: CALCU
Domain Type: <Local Computer>
Applied Group Policy Objects
N/A
The following GPOs were not applied because they were filtered out
Local Group Policy
Filtering: Not Applied (Empty)
The computer is a part of the following security groups
System Mandatory Level
Everyone
boinc_admins
BUILTIN\Users
NT AUTHORITY\SERVICE
CONSOLE LOGON
NT AUTHORITY\Authenticated Users
This Organization
BDESVC
BITS
CertPropSvc
DsmSvc
Eaphost
hkmsvc
IKEEXT
iphlpsvc
LanmanServer
lfsvc
MMCSS
MSiSCSI
NcaSvc
RasAuto
RasMan
RemoteAccess
Schedule
SCPolicySvc
SENS
SessionEnv
SharedAccess
ShellHWDetection
wercplsupport
Winmgmt
wlidsvc
wuauserv
LOCAL
BUILTIN\Administrators
Resultant Set Of Policies for Computer
Software Installations
N/A
Startup Scripts
N/A
Shutdown Scripts
N/A
Account Policies
N/A
Audit Policy
N/A
User Rights
N/A
Security Options
N/A
N/A
Event Log Settings
N/A
Restricted Groups
N/A
System Services
N/A
Registry Settings
N/A
File System Settings
N/A
Public Key Policies
N/A
Administrative Templates
N/A
here are
    button
  2. Click on Run -> inside the run box type in gpedit -> press ok
  3. Expand Computer Configuration -> Administrative templates -> All settings
  4. Are any enabled?
  5. Expand User Configuration -> Administrative templates -> All settings
  6. Are any enabled?
Gpedit dont open. I received a message: Windows cannot find gpedit,exe. I think that the file is not avaible in Win 8.1
Na that will only work for windows 8 pro, I wasn't sure if you had home or pro.
    button
    reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft" > 0 & notepad 0
    reg query "HKEY_CURRENT_USER\Software\Policies\Microsoft\Windows" > 1 & notepad 1
  4. Please post the contents of 1.txt and 0.txt back into this thread.
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Cryptography
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Internet Explorer
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\PCHealth
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Peernet
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\SystemCertificates
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT
1.txt
HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\CurrentVersion
HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\Windows Error Reporting
Ah, there we go :)
1.txt
[B]HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\[COLOR="#FF0000"]Windows Error Reporting[/COLOR][/B]
Open cmd as admin again and run the following:
reg delete "HKEY_CURRENT_USER\SOFTWARE\Policies\Microsoft\Windows\Windows Error Reporting" /f
Once done please restart your computer and try the error reporting again.
