Event ID 41 troubleshooting
usasma
Retired Admin
From Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
An event 41 is used to report that something unexpected happened that prevented Windows from shutting down correctly. There may be insufficient information to explicitly define what happened. To determine what may have happened and to identify a potential resolution, it is important to know what the computer was doing at the time just before the event occurred.
If event 41 is logged because power to the computer was interrupted, consider obtaining an uninterruptible power supply (UPS) such as a battery backup power supply. An underpowered or failing power supply may cause this behavior. For example, if you added RAM or additional devices or hard disks when this problem began, the power supply may cause the problem.
An event 41 can occur in the following scenarios.
Scenario 1: The computer restarts, and there is a Stop error BugcheckCode in the event data
Click here to show/hide scenario
Scenario 2: The computer is shut down by pressing and holding the power button
Scenario 3: The system randomly restarts and no Stop error BugcheckCode is listed, or the computer is completely unresponsive (hard hang)
Primarily check:
Overclocking: Disable overclocking to see whether the issue occurs when the system is run at the correct speed.
Check the memory: Verify the memory by using a memory checker. Verify that each memory chip is the same speed and that it is configured correctly in the system.
Power supply: Make sure that the power supply has enough wattage to appropriately handle the installed devices. If you added memory, installed a newer processor, installed additional drives, or added external devices, such devices can require more energy than the current power supply can provide consistently.
Overheating: Check whether the system is overheating by examining the internal temperature of the hardware.
Defaults: Reset the system back to the system defaults to see whether the issues occur when the system is running in its default configuration.
Interestingly, BugcheckCode 159 (in decimal) is equivalent to the BugcheckCode 9F in hexadecimal (from Scenario 1)
Thank you for this, John. I often have to point out to people the difference between a system crashing all the time without BSODs and one that's crashing with BSODs, and perusing the syslog for this contrast is very helpful in that endeavor.
