[HELP] Server 2008 R2 - CheckSUR and SFC can't repair + possible malware in scheduled task
Shin
25
Hello,
I'm experiencing serious integrity issues on a Windows Server 2008 R2 machine.
- `CheckSUR` and `sfc /scannow` both fail to repair system files.
- `FRST` reveals suspicious scheduled tasks (e.g., MsInputMonitor) that seem to delete security-related registry entries.
- Possible unauthorized use of suspicious `winreg.exe` and `winacl.exe` in Temp folder.
I suspect there is hidden malware interfering with updates and logging.
Could you please review the attached logs and provide a custom `SFCFix.zip` package and/or malware removal fix?
Thanks in advance!
**Attached Logs:**
- CheckSUR.log
- CheckSUR.persist.log
- CBS.log / part
- FRST.txt
- Addition.txt
- Shortcut.txt
I've attached the results of the ComponentScanner for your review.
Please take a look when you have a chance.
Let me know if you need anything else from my side.
Thanks again for your help!
Hi, Shin!
Thanks for your patience.
Is this computer a personal computer or a business computer?
In addition, have in mind that Microsoft Windows Server 2008 R2 Enterprise stopped getting security updates 5 years ago. We don't use to clean outdated systems, since they basically consist of a security risk. Even if you clean such a system, it is likely going to get infected soon or later, because of that.
If it is a personal computer, I recommend you get a version of Windows 11 (if your computer supports it) suitable for an ordinary user (Home or Pro), and make a fresh start. There are some reputable sites selling Windows 11 at a low price these days.
Let me know about your thoughts.
This is a computer that is currently being used as a server. There has been a problem with an attack, etc., so I asked you to know this place while taking various measures. I'm currently running a website, so I'm going to solve the problem to some extent and transfer the server. There are problems with the mail system and the schedule system, but I couldn't log in either, so I came all the way here. Can you help me?
You are welcome.
Take care, Shin.
