help with sfc
papitomvp
i ran sfc and came back with errors, i dont have much knowledge in this area so im begging someone to help. i have a high end pc and i dont get any error codes but just stutters and sound loops and it can get pretty annoying. thanks
Hello papitomvp, welcome to Sysnative!
This will fix your SFC problem, but I'm fairly sure it's not causing your other problems:
DISM /RestoreHealth Scan
  1. Right-click on the Start
SFC Scan
  1. Click on the Start
Tom
