R relztrah Contributor Joined Mar 25, 2019 Posts 183 Mar 25, 2019 #1 There's a way to display the percentage of battery charge remaining because I've seen it on another identical tablet PC. I only use this tablet at the gym and leave it in my gym clothes bag so it would be nice to know when it is getting below 10% rather than trying to guess from the bar. I looked through all settings, but didn't see where to enable the percentage to display.
Digerati ModeratorHardware ExpertMicrosoft MVP (Ret.) Staff member Joined Aug 28, 2012 Posts 4,950 Location Nebraska, USA Mar 25, 2019 #2 Does it show the percentage when you hover the mouse pointer over the battery icon? If not, and you are sure there is no setting you overlooked, then I can only guess the other computer you saw was running a battery status monitoring program. I suggest you look through what is available and pick the one that suits you best.
Tekno Venus Senior Administrator, Developer Staff member Joined Jul 21, 2012 Posts 7,237 Location UK Mar 25, 2019 #3 There is no way to do this natively in Windows. However, Lenovo bundles some software called Lenovo Vantage with their machines. Inside Vantage, there's a battery gauge option (somewhere, not exactly sure where it is) which will turn on a battery % meter in the taskbar. More info here: https://forums.lenovo.com/t5/ThinkP...le-green-battery-icon-on-taskbar/td-p/3667701 If you can't find the option within Vantage, I've seen people reporting that it has been removed in some versions. There's another option, which is a program called BatteryBar. I used it a long time ago, but I believe it still works with Windows 10: BatteryBar Pro: Windows Battery Life Tracker. There's a paid and free version
R relztrah Contributor Joined Mar 25, 2019 Posts 183 Mar 26, 2019 #4 Here is what I'm talking about. This is from my second Lenovo ThinkPad. Both of them show Lenovo Vantage in the apps list, but when I tap on it, it just gives a splash screen and then goes away. There is no actual app that opens and allows me to make any changes, unless I'm missing something. Thanks for the tips. I'll follow them up when I get some time.
Digerati ModeratorHardware ExpertMicrosoft MVP (Ret.) Staff member Joined Aug 28, 2012 Posts 4,950 Location Nebraska, USA Mar 26, 2019 #5 Instead of tapping on the battery icon, what if you right click on it? Does that then give you any options to open the app or get to a settings page?
Tekno Venus Senior Administrator, Developer Staff member Joined Jul 21, 2012 Posts 7,237 Location UK Mar 26, 2019 #6 If you right click on the taskbar, and hover over Toolbars, there might be an option to enable the Lenovo Battery Meter there. The screenshot you've given is definitely the Lenovo battery meter, I've seen it on Lenovo's I've used in the past - it's just a case of working out how to enable it!
R relztrah Contributor Joined Mar 25, 2019 Posts 183 Mar 26, 2019 #7 It's a tablet, so there's no mouse or clicking.
Tekno Venus Senior Administrator, Developer Staff member Joined Jul 21, 2012 Posts 7,237 Location UK Mar 26, 2019 #8 You can still right click on a tablet - just tap and hold
R relztrah Contributor Joined Mar 25, 2019 Posts 183 Mar 27, 2019 #9 Here's what I see when I long press: And none of those options has a setting that allows me to display the percentage of battery power left. But the good news is that I have a solution! I have an extra cellphone power pack that I put in my gym clothes bag so when my battery dies while I'm on the elliptical machine in the middle of an article, I can simply plug in the power pack and then charge the tablet when I get home. Fortunately this table has an alert when battery power gets low, so I have a few minutes warning. I appreciate all the suggestions from other members here, but this really isn't enough of an issue that I'm going to pursue it further. I'll just use the power pack. Thanks again.
jcgriff2 Co-Founder / AdminBSOD Instructor/ExpertMicrosoft MVP (Ret.) Staff member Joined Feb 19, 2012 Posts 21,541 Location New Jersey Shore Mar 31, 2019 #10 I found this on Google - How do I show battery percentage on Lenovo? Re: Display Battery Percentage Pull down from the top to reveal the Notification center. Tap on the Settings gear symbol on the top right corner. This will show the Notification Center menu. Tap on "Display Batter Indicator". Select "Percentage" to show the percantage charge remaining on the Notification line. Click to expand... Display Battery Percentage Regards. . . jcgriff2
jcgriff2 Co-Founder / AdminBSOD Instructor/ExpertMicrosoft MVP (Ret.) Staff member Joined Feb 19, 2012 Posts 21,541 Location New Jersey Shore Mar 31, 2019 #11 I found this too - How to display battery percentage - Smartphone/Tablet - US
