IE 10 Will Not Install 9C59 #2
jentringer
Well-known member
Another machine with the same issue as my previous thread. Let me know where you want to start.
Please start with the following.
Step#1 - Gather Info
1. Download SFCFix.exe and save this to your Desktop.
2. Save any open documents and close all open windows.
3. Double click on SFCFix.exe to open it.
4. Follow all on screen instructions and upon completion, a file should be created on your Desktop named SFCFix.txt.
5. Please post the contents of this log in your next post. Thank you.
Thanks.
SFC Scan
  1. Click on the Start
Thank you. One more log please.
Good. It's always important to access the health of the machine's servicing before continuing.
Let's see how similar the issue is on this machine.
Attempt IE10 install/Collect Logs
1. Download the IE10 offline installer from here and save to your desktop.
2. If it fails to install, then please zip up and attach the following logs.
C:\Windows\WindowsUpdate.log
C:\Windows\Logs\CBS\CBS.log
C:\Windows\IE10_Main.log
Bummer. On your last thread/machine we worked on there were 29 different component files/folders that we had to replace. Here was the first one.
x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_10.2.9200.[COLOR=#ff0000]17377[/COLOR]_none_b203fcf00292a6b0\ieproxy.dll
Here is the first one on this machine.
x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_10.2.9200.[COLOR=#ff0000]16521[/COLOR]_none_b1e9e27002a6c8f2\ieproxy.dll
Notice that the version numbers are different. So we may not be able to use all the fixes that we did for the first machine but I think I know how to identify all of the issues in one run. Please do the following.
Step#1 - SFCFix Script
Step#2 - Install IE10 Manually
Please install IE10 manually using my previous steps. If it doesn't install please zip/attach the current CBS.log.
Step#3 - Retrieve Components Hive
Items for your next post
1. SFCFix.txt
2. CBS.log if needed
3. Components hive
This should allow you to grab the components hive.
  • Now right click on the COMPONENTS file that is on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Thanks for the info. Please do the following.
1. SFCFix.txt
2015-07-01 14:00:12, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-setup-support_31bf3856ad364e35_10.2.9200.16521_none_e78bb335168f75fb\iesetup.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2015-07-01 15:48:03, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-ielowutil_31bf3856ad364e35_10.2.9200.16521_none_28310a372950e6b8\ielowutil.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2015-07-01 16:03:18, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-directxtransforms_31bf3856ad364e35_10.2.9200.16521_none_b9814d2039ba3ef4\dxtmsft.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
